How can a tractor overheat on the coldest day of the decade?
   / How can a tractor overheat on the coldest day of the decade? #11
Saw TX, freeze and knew exactly what happened. Amazing how loopholes and corner cutting shows its ugly head when things get a bit abnormal. Up here you would never find water in a radiator or a shallow water pipe going into someone’s house. I grew up in east tx and only remember 1 time we got snow.
Got that right. You can't hire a plumber or buy a plumbing fixture or a piece of copper pipe to save your life from Central Texas southward right now. Our houses are definitely not built for that kind of cold.
You probably also remember that you can lay a pipe on the ground, sprinkle some dust on top and it won't freeze -- in an ordinary winter!
   / How can a tractor overheat on the coldest day of the decade? #13
Do tractors have thermostats? they do go bad and you will defiantly
over heat!
on anti-freeze I mix for -50 degrees so never have a problem with
radiator also change hoses every 5 years with new anti-freeze
willy
CHAMPION C80C MOTOR GRADER (A52707)
CHAMPION C80C...
2018 JCB Truss Jib Telescopic Hydraulic Boom (A53421)
2018 JCB Truss Jib...
2013 International WorkStar 7400 Altec AM650 50ft Material Handling Insulated Bucket Truck (A55852)
2013 International...
2019 Autocar ACX Xpeditor T/A New Way 31ASL 31yd Automated Side Loader Garbage Truck (A55852)
2019 Autocar ACX...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
2023 Kubota KX057-5 Compact Excavator (A55315)
2023 Kubota...
