Homemade Two wheel tractor
/ Homemade Two wheel tractor
20190328_140130.jpg 20190328_140604.jpg 20190328_140612.jpg 20190328_153510.jpg 20190328_153517.jpg 20190328_153525.jpg
/ Homemade Two wheel tractor #44
so, how did you slot the axle for the wheel hubs??.. a milling machine is needed for that because of the tight tolerances and accuracy needed..
/ Homemade Two wheel tractor #45
I don’t think he did. It looks like the hubs are clamped onto the axles.
/ Homemade Two wheel tractor #47
Can mill it on the lathe
/ Homemade Two wheel tractor #48
how?. I've worked for a defense contractor for years making parts for jet fighters and helicopters, using all kinds of machines, and that was NEVER done.. the only way possible to do that on a lathe is VERY unconventional, you'd need to lock up the chuck, either by tying the brake on with a rope, or make a jig for that, and drill the ends of the shaft for a live center, and make it tight against the shaft, and make a special bit with the exact width needed, and use the power feed to essentially scrape the steel horizontally a little at a time. and I don't see the shaft drilled for a live center..
/ Homemade Two wheel tractor #49
He built a horizontal milling machine. Anyways, can be done on the lathe, specially if you have a milling attachment like he also built in his lathe.
/ Homemade Two wheel tractor #50
Mount shaft to cross slide, end mill or keyset cutter mounted in the spindle. Done all the time.
Would like to see the mill the OP made.
/ Homemade Two wheel tractor #51
Put the endmill in the chuck to spin. Mount the shaft in your toolholder.
/ Homemade Two wheel tractor #54
you my friend got some great skills, been watching your vids,and vewing post here,
i am blown away at the lathe, an mill attatchment you have made and the other mill,and the tractor, i really enjoy building stuff from scrap as well,
enjoying the build and getting some great ideas,
thanks,godbless
/ Homemade Two wheel tractor #56
This is very cool.
New/Unused CFG Industrial H15R Mini Excavator (A65583)
New/Unused CFG...
2022 Blue Diamond Brush Cutter (A64126)
2022 Blue Diamond...
213130 (A64276)
213130 (A64276)
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A61306)
2016 RAM 5500...
MASSEY FERGUSON 240 TRACTOR (A64280)
MASSEY FERGUSON...
2008 23ft. Zodiac Hurricane Inflatable RIB with 2007 25ft Myco T/A Aluminum Boat Trailer (A61574)
2008 23ft. Zodiac...
