Homemade Two wheel tractor
/ Homemade Two wheel tractor
20190328_140130.jpg 20190328_140604.jpg 20190328_140612.jpg 20190328_153510.jpg 20190328_153517.jpg 20190328_153525.jpg
/ Homemade Two wheel tractor #44
so, how did you slot the axle for the wheel hubs??.. a milling machine is needed for that because of the tight tolerances and accuracy needed..
/ Homemade Two wheel tractor #45
I don’t think he did. It looks like the hubs are clamped onto the axles.
/ Homemade Two wheel tractor #47
Can mill it on the lathe
/ Homemade Two wheel tractor #48
how?. I've worked for a defense contractor for years making parts for jet fighters and helicopters, using all kinds of machines, and that was NEVER done.. the only way possible to do that on a lathe is VERY unconventional, you'd need to lock up the chuck, either by tying the brake on with a rope, or make a jig for that, and drill the ends of the shaft for a live center, and make it tight against the shaft, and make a special bit with the exact width needed, and use the power feed to essentially scrape the steel horizontally a little at a time. and I don't see the shaft drilled for a live center..
/ Homemade Two wheel tractor #49
He built a horizontal milling machine. Anyways, can be done on the lathe, specially if you have a milling attachment like he also built in his lathe.
/ Homemade Two wheel tractor #50
Mount shaft to cross slide, end mill or keyset cutter mounted in the spindle. Done all the time.
Would like to see the mill the OP made.
/ Homemade Two wheel tractor #51
Put the endmill in the chuck to spin. Mount the shaft in your toolholder.
/ Homemade Two wheel tractor #54
you my friend got some great skills, been watching your vids,and vewing post here,
i am blown away at the lathe, an mill attatchment you have made and the other mill,and the tractor, i really enjoy building stuff from scrap as well,
enjoying the build and getting some great ideas,
thanks,godbless
/ Homemade Two wheel tractor #56
This is very cool.
2002 Ford F-550 Dump Truck, VIN # 1FDAF56F32EC86522 (A61165)
2002 Ford F-550...
1991 FORD F-800 BED TRUCK (A60736)
1991 FORD F-800...
2021 VERMEER S925TX STAND ON SKIDSTEER (A52709)
2021 VERMEER...
John Deere 24in Digging Tooth Bucket Excavator Attachment (A60352)
John Deere 24in...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61567)
2025 Kivel 48in...
832718 (A61166)
832718 (A61166)
