Homemade Two wheel tractor
/ Homemade Two wheel tractor
20190328_140130.jpg 20190328_140604.jpg 20190328_140612.jpg 20190328_153510.jpg 20190328_153517.jpg 20190328_153525.jpg
/ Homemade Two wheel tractor #44
so, how did you slot the axle for the wheel hubs??.. a milling machine is needed for that because of the tight tolerances and accuracy needed..
/ Homemade Two wheel tractor #45
I don’t think he did. It looks like the hubs are clamped onto the axles.
/ Homemade Two wheel tractor #47
Can mill it on the lathe
/ Homemade Two wheel tractor #48
how?. I've worked for a defense contractor for years making parts for jet fighters and helicopters, using all kinds of machines, and that was NEVER done.. the only way possible to do that on a lathe is VERY unconventional, you'd need to lock up the chuck, either by tying the brake on with a rope, or make a jig for that, and drill the ends of the shaft for a live center, and make it tight against the shaft, and make a special bit with the exact width needed, and use the power feed to essentially scrape the steel horizontally a little at a time. and I don't see the shaft drilled for a live center..
/ Homemade Two wheel tractor #49
He built a horizontal milling machine. Anyways, can be done on the lathe, specially if you have a milling attachment like he also built in his lathe.
/ Homemade Two wheel tractor #50
Mount shaft to cross slide, end mill or keyset cutter mounted in the spindle. Done all the time.
Would like to see the mill the OP made.
/ Homemade Two wheel tractor #51
Put the endmill in the chuck to spin. Mount the shaft in your toolholder.
/ Homemade Two wheel tractor #54
you my friend got some great skills, been watching your vids,and vewing post here,
i am blown away at the lathe, an mill attatchment you have made and the other mill,and the tractor, i really enjoy building stuff from scrap as well,
enjoying the build and getting some great ideas,
thanks,godbless
/ Homemade Two wheel tractor #56
This is very cool.
John Deere 4040 Tractor (A64047)
John Deere 4040...
2023 Hustler X-One Zero Turn (A63116)
2023 Hustler X-One...
HOMEMADE TIRE DRAG (A63291)
HOMEMADE TIRE DRAG...
MILITARY STYLE S/A CARGO TRAILER (A63291)
MILITARY STYLE S/A...
Skid Steer Flat Bottom Grapple (A64047)
Skid Steer Flat...
Arrow Quip 8800LV Cattle Chute with Sternum Bar and Head Holder (A64047)
Arrow Quip 8800LV...
