Home-made attachments...
/ Home-made attachments... #261
I am trying to see how you anchored the 2x4's to the box blade but cant determine. Next to last picture appears to show bolt going through ripper into 2x4. Is that correct?
Exactly. Those are 3-inch carriage bolts, two large washers, and a locking nut.
For my use, a little play with the ripper while unloaded is not problem. Loading the coral panels onto the system allows the wood to sway left or right as the ripper moves slightly. This helps to make the loading easier. When everything is loaded onto the wood support arms, the weight keeps things from shifting around. My farm has rolling hills, nothing has ever fallen off nor shifted with this setup.
/ Home-made attachments... #262
I posted the begining stages of this one a year ago on this thread. (and propably a few other times):laughing:
Kinda proud of this one.
Wow, that's sweet! Very professional. I assume that winch is hydraulic, possibly off a tow truck?
Also, it'd be great to have a link to the build thread on that FOPS :thumbsup:
EDIT: Shoot, just looked at the date of that post!
/ Home-made attachments... #263
What is the concern about the date of his post?
This thread started in January of 2014, good info is ageless. :thumbsup:
/ Home-made attachments... #264
Yes, noted. Just thought it might be a bit uncouth to expect a response on a post that's over a year old.
:newhere:
/ Home-made attachments... #266
20190405_115628.jpg A friend let me borrow this for stump removal .
/ Home-made attachments... #268
I love threads like this because I love building stuff out of steel. Here are a few that I have built in the two years I have had my tractor. first of all sorry for the sideways pictures, they were taken with my phone and uploaded to the site before I knew how to properly orientate them on my phone. The first is my attempt to turn my rear blade into a box blade by building removeable side plates. The second is a logging capstan winch/trailer mover. The third is a small land leveler/plane, and the last one is a root bucket grapple.
/ Home-made attachments... #269
That's the ultimate redneck common sense innovation.
Clevis on the 3 point, I would have never thought of that. It looks like it should work well.
It does , it is free swiveling so it works in both directions . The tooth turns itself in the direction of travel when it engages the ground.
/ Home-made attachments... #270
Cool. So you can rip out the phone line one way and get the Cable TV coming back. lol
/ Home-made attachments... #272
Where is the tipping point for the wood box please?
We need the post number of the post that you are asking about.
Or go back to it and click "Reply With Quote" and ask again.
/ Home-made attachments... #274
In post #15, there is a tipping wood box. How is the tipping point located please?
Search for: "tractor link box" on Google and check the images. It might help you.
I have one. There are different styles. Mine pivots on the lower pins. Others have a small frame going about halfway on the box with the pivot pins around the middle of the box.
/ Home-made attachments... #275
/ Home-made attachments... #277
NOT SURE IF THIS IS THE RIGHT THREAD FOR THIS, BUT---I HAVE A KING KUTTER ROTORY MOWER--6"-- TAG-A-LONG I'VE USED FOR YEARS BEHIND MY JD-A. I NEED A TPH MOWER FOR THE KIOTTI. I'M THINKING OF CONVERTING THE TRAIL MOWER TO A TPH. ANY BODY DONE THIS OR HAVE ANY ADVICE. I WOULD PICK UP AN OLD TPH MOWER OR PARTS AND PUT THEM ON THE TAG-A-LONG. I CAN WELD AND PULL WRENCHES. THANKS
John Deere 12in Channel Tooth Bucket Excavator Attachment (A64194)
John Deere 12in...
2008 23ft. Zodiac Hurricane Inflatable RIB with 2007 25ft Myco T/A Aluminum Boat Trailer (A61574)
2008 23ft. Zodiac...
LMC 2-Row Planter BYJ-2F  Stainless Steel Fertilizer Boxes, Ground-Driven (A61307)
LMC 2-Row Planter...
2007 Chevrolet Silverado 3500HD (A60462)
2007 Chevrolet...
2015 GMC 3500 HD 4x4 Crew Cab Pickup Truck (A64194)
2015 GMC 3500 HD...
2025 Kubota SVL75-3HFWCC High Flow Cab Track Loader - 70 hours
2025 Kubota...
