bmaverick
Super Member
- Joined
- Sep 17, 2013
- Messages
- 7,292
- Location
- Beloit-WI
- Tractor
- Yanmar YM2610 ■YANMAR GURU■ EXTRAORDINAIRE
I am trying to see how you anchored the 2x4's to the box blade but cant determine. Next to last picture appears to show bolt going through ripper into 2x4. Is that correct?
Exactly. Those are 3-inch carriage bolts, two large washers, and a locking nut.
For my use, a little play with the ripper while unloaded is not problem. Loading the coral panels onto the system allows the wood to sway left or right as the ripper moves slightly. This helps to make the loading easier. When everything is loaded onto the wood support arms, the weight keeps things from shifting around. My farm has rolling hills, nothing has ever fallen off nor shifted with this setup.
