Hobbs or Guide style?
/ Hobbs or Guide style? #1
jhansen17
Omaha, NE
John Deere 630
I need to replace the bezel on one of the rear work lights on a JD 4030. Looking around online it looks like I need to know if the light is a Hobbs or Guide style? Is there an easy way to tell the difference?
/ Hobbs or Guide style? #2
Maybe tell us more about the dilemna (Hobbs or Guide) as well as what you found online.
Have you found a bezel of either type?
Looking for replacing with original, or just to get a work light?
Sure. The old bezel is dried up and cracking and the bulb was burned out. To remove the bulb I had to remove the bezel. Before I replace the bulb, I want to have a replacement bezel. So I did some searching online and found what looks like two main options: Guide style and Hobbs style. I’m just looking to restore light capacity at most minimal cost and hassle. Here are the two options at Steiner. So far I can’t tell from looking at my existing light which style it is.
/ Hobbs or Guide style? #4
Okay, then I'd suggest Amazon for an LED work light.. get two for $18 and can't beat the amount of light. I put these on my tractor.
/ Hobbs or Guide style? #5
The name should be stamped on the bezel. I know for sure Hobbs are stamped, I would think would be for Guide as well. As for buying aftermarket bezels I have had no luck. They don't seem to fit. I have purchased JD replacements and will say that's not cheap. Probably double the price of what you listed. I'll see what my 4430 has on the cab and get a picture for you.
/ Hobbs or Guide style? #6
Appears the name is in the housing
UNUSED REMOTE CONTROLLED BULLDOZER (A62130)
UNUSED REMOTE...
2015 Sealine F380 Flybridge Motor Yacht Boat (A59231)
2015 Sealine F380...
TAKEUCHI-VIRNIG TRRG72 - 72" HYD ROOT RAKE GRAPPLE (A62129)
TAKEUCHI-VIRNIG...
17395SFL (A61568)
17395SFL (A61568)
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
