Hobbs or Guide style?
/ Hobbs or Guide style? #1
jhansen17
Member
Omaha, NE
John Deere 630
I need to replace the bezel on one of the rear work lights on a JD 4030. Looking around online it looks like I need to know if the light is a Hobbs or Guide style? Is there an easy way to tell the difference?
/ Hobbs or Guide style? #2
Maybe tell us more about the dilemna (Hobbs or Guide) as well as what you found online.
Have you found a bezel of either type?
Looking for replacing with original, or just to get a work light?
Sure. The old bezel is dried up and cracking and the bulb was burned out. To remove the bulb I had to remove the bezel. Before I replace the bulb, I want to have a replacement bezel. So I did some searching online and found what looks like two main options: Guide style and Hobbs style. I’m just looking to restore light capacity at most minimal cost and hassle. Here are the two options at Steiner. So far I can’t tell from looking at my existing light which style it is.
/ Hobbs or Guide style? #4
Okay, then I'd suggest Amazon for an LED work light.. get two for $18 and can't beat the amount of light. I put these on my tractor.
/ Hobbs or Guide style? #5
The name should be stamped on the bezel. I know for sure Hobbs are stamped, I would think would be for Guide as well. As for buying aftermarket bezels I have had no luck. They don't seem to fit. I have purchased JD replacements and will say that's not cheap. Probably double the price of what you listed. I'll see what my 4430 has on the cab and get a picture for you.
/ Hobbs or Guide style? #6
Appears the name is in the housing
2019 Chevrolet Silverado 1500 Pickup Truck (A55973)
2019 Chevrolet...
Kubota LA525 Front Loader Tractor Arm Attachment (A59228)
Kubota LA525 Front...
LMC Ag 25 Gallon Sprayer (A60463)
LMC Ag 25 Gallon...
2014 POLAR TANK CRUDE TRAILER (A60736)
2014 POLAR TANK...
2018 Hyundai Robex 35 (A60462)
2018 Hyundai Robex...
2021 MULTIQUIP WHISPER PORTABLE AC GENERATOR (A59823)
2021 MULTIQUIP...
