high preser fuel pipe broken
/ high preser fuel pipe broken #1
iyel
deutz
Hi everyone,
please if any one can help me.
i have a tractor that have a fuel pipe each time i change it it get broken or get leak.
the pipe is between the injection pump and the injector.
the pipe is well fixed.
thank you in advance.
/ high preser fuel pipe broken #2
Your replacing the line with a new line and it still breaks?
Can you post a pic?
/ high preser fuel pipe broken #3
Did you put the rubber isolators back on? Sounds like you have a vibration problem.
yes that exactly what i thought .
then i put the rubber it has reduce but not eliminate the problem totally.
the pipe get lose by it self
/ high preser fuel pipe broken #5
Do the clamps come loose, or the nuts at each end of the line?
Aaron Z
Aaron Z
it just the nut from the bottom how get loose
/ high preser fuel pipe broken #8
I'm wondering if all the clamps are in place as original
The clamps go between all the lines, they help reduce the vibration between them. Either that or there is something damaged with the threads from when the first line came loose
I believe it's just the clamps; when i tight them very well they it haven't get leak yet. thank you bro
2007 Isuzu NPR-HD Crew Cab Knapheide Service Truck (A64556)
2007 Isuzu NPR-HD...
Toro Mower (A64194)
Toro Mower (A64194)
2025 IRANCH Tire Changing Machine (A64194)
2025 IRANCH Tire...
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
John Deere 2840 Tractor (A64047)
John Deere 2840...
Sunflower Yard Art (A64557)
Sunflower Yard Art...
