high preser fuel pipe broken
/ high preser fuel pipe broken #1
iyel
deutz
Hi everyone,
please if any one can help me.
i have a tractor that have a fuel pipe each time i change it it get broken or get leak.
the pipe is between the injection pump and the injector.
the pipe is well fixed.
thank you in advance.
/ high preser fuel pipe broken #2
Your replacing the line with a new line and it still breaks?
Can you post a pic?
/ high preser fuel pipe broken #3
Did you put the rubber isolators back on? Sounds like you have a vibration problem.
yes that exactly what i thought .
then i put the rubber it has reduce but not eliminate the problem totally.
the pipe get lose by it self
/ high preser fuel pipe broken #5
Do the clamps come loose, or the nuts at each end of the line?
Aaron Z
Aaron Z
it just the nut from the bottom how get loose
/ high preser fuel pipe broken #8
I'm wondering if all the clamps are in place as original
The clamps go between all the lines, they help reduce the vibration between them. Either that or there is something damaged with the threads from when the first line came loose
I believe it's just the clamps; when i tight them very well they it haven't get leak yet. thank you bro
Caterpillar D5M and D5M LGP Dozer Service and Parts Manuals (A63117)
Caterpillar D5M...
2012 Peterbilt 367 Sleeper Truck, VIN # 1XPTD40X5CD149943 (A65563)
2012 Peterbilt 367...
(INOP) 2012 INTERNATIONAL DURASTAR 4300 SBA TRUCK (A59823)
(INOP) 2012...
Year: 2018 Make: Towmaster Model: TC-16 Vehicle Type: Trailer Mileage: Plate: Body Type: Trim Lev... (A61567)
Year: 2018 Make...
Hydraulic rail grinder (A61307)
Hydraulic rail...
Cast Iron Anvil (A61574)
Cast Iron Anvil...
