high preser fuel pipe broken
/ high preser fuel pipe broken #1
iyel
deutz
Hi everyone,
please if any one can help me.
i have a tractor that have a fuel pipe each time i change it it get broken or get leak.
the pipe is between the injection pump and the injector.
the pipe is well fixed.
thank you in advance.
/ high preser fuel pipe broken #2
Your replacing the line with a new line and it still breaks?
Can you post a pic?
/ high preser fuel pipe broken #3
Did you put the rubber isolators back on? Sounds like you have a vibration problem.
yes that exactly what i thought .
then i put the rubber it has reduce but not eliminate the problem totally.
the pipe get lose by it self
/ high preser fuel pipe broken #5
Do the clamps come loose, or the nuts at each end of the line?
Aaron Z
Aaron Z
it just the nut from the bottom how get loose
/ high preser fuel pipe broken #8
I'm wondering if all the clamps are in place as original
The clamps go between all the lines, they help reduce the vibration between them. Either that or there is something damaged with the threads from when the first line came loose
I believe it's just the clamps; when i tight them very well they it haven't get leak yet. thank you bro
UNUSED WOLVERINE 3PT QUICK HITCH (A64281)
UNUSED WOLVERINE...
2019 CATERPILLAR M316F MOBILE EXCAVATOR (A63276)
2019 CATERPILLAR...
2005 Kubota L3130 (A60462)
2005 Kubota L3130...
(2) UNUSED 14.9-28 TIRES W/ 8 LUG RIMS (A64280)
(2) UNUSED 14.9-28...
2023 CATERPILLAR 320 EXCAVATOR (A62129)
2023 CATERPILLAR...
(INOP) 2013 KAWASAKI MULE 4010 UTV (A64280)
(INOP) 2013...
