high preser fuel pipe broken
/ high preser fuel pipe broken #1
iyel
deutz
Hi everyone,
please if any one can help me.
i have a tractor that have a fuel pipe each time i change it it get broken or get leak.
the pipe is between the injection pump and the injector.
the pipe is well fixed.
thank you in advance.
/ high preser fuel pipe broken #2
Your replacing the line with a new line and it still breaks?
Can you post a pic?
/ high preser fuel pipe broken #3
Did you put the rubber isolators back on? Sounds like you have a vibration problem.
yes that exactly what i thought .
then i put the rubber it has reduce but not eliminate the problem totally.
the pipe get lose by it self
/ high preser fuel pipe broken #5
Do the clamps come loose, or the nuts at each end of the line?
Aaron Z
Aaron Z
it just the nut from the bottom how get loose
/ high preser fuel pipe broken #8
I'm wondering if all the clamps are in place as original
The clamps go between all the lines, they help reduce the vibration between them. Either that or there is something damaged with the threads from when the first line came loose
I believe it's just the clamps; when i tight them very well they it haven't get leak yet. thank you bro
2025 Greatbear Rachet Tie Down & Flatpack Tool Box (A61567)
2025 Greatbear...
17109SFL (A61569)
17109SFL (A61569)
Caterpillar 325/325L/325LN Excavator Service and Parts Manuals (A63117)
Caterpillar...
2008 Ford F-550 4x4 Landscape Dump Truck with Lift Gate (A61568)
2008 Ford F-550...
Morbark 30/36 Wood Chipper (A62613)
Morbark 30/36 Wood...
Kubota LA525 Front Loader Tractor Arm Attachment (A59228)
Kubota LA525 Front...
