high preser fuel pipe broken
/ high preser fuel pipe broken #1
iyel
deutz
Hi everyone,
please if any one can help me.
i have a tractor that have a fuel pipe each time i change it it get broken or get leak.
the pipe is between the injection pump and the injector.
the pipe is well fixed.
thank you in advance.
/ high preser fuel pipe broken #2
Your replacing the line with a new line and it still breaks?
Can you post a pic?
/ high preser fuel pipe broken #3
Did you put the rubber isolators back on? Sounds like you have a vibration problem.
yes that exactly what i thought .
then i put the rubber it has reduce but not eliminate the problem totally.
the pipe get lose by it self
/ high preser fuel pipe broken #5
Do the clamps come loose, or the nuts at each end of the line?
Aaron Z
Aaron Z
it just the nut from the bottom how get loose
/ high preser fuel pipe broken #8
I'm wondering if all the clamps are in place as original
The clamps go between all the lines, they help reduce the vibration between them. Either that or there is something damaged with the threads from when the first line came loose
I believe it's just the clamps; when i tight them very well they it haven't get leak yet. thank you bro
2020 FREIGHTLINER M2 106 4X2 S/A 26FT TARP SIDE BOX TRUCK (A59912)
2020 FREIGHTLINER...
2016 Cadillac CTS Sedan (A61574)
2016 Cadillac CTS...
2012 GMC Sierra 1500 SLE 4x4 Crew Cab Pickup Truck (A61573)
2012 GMC Sierra...
2018 VOLVO VNL TANDEM AXLE DAY CAB (A59912)
2018 VOLVO VNL...
Fendt FT900 Front Fenders (A63117)
Fendt FT900 Front...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
