3-Point Hitch HF Quick Hitch to Bush Hog problem
   / HF Quick Hitch to Bush Hog problem #1
vulcancowboy
Duncannon, Pennsylvania
Kubota L3400 HST
Just picked up a Harbor Freight quick hitch. I put it on my tractor (Kubota L3400) and I'm having an issue with the top connector. Either the hook on the QH needs to go up, or I need to rework the mower hitch. Am I missing something? Pic attached.
   / HF Quick Hitch to Bush Hog problem #2
Take the top of the hitch apart and reassemble it with the short link behind the A-frame. But it looks like your bottom pins are too far from the top pin. Standard is 18 inches apart and for quick-hitch, 15 inches.
You may need an adapter. Some ideas:
Bruce
   / HF Quick Hitch to Bush Hog problem #3
take bottom bolt out of hook replace top bolt with grade 8 tilt it up and slide you pin in .
BCP, The vertical distance from the CL of the bottom pins to the CL of the top pin is ~ 23". The info you provided is very helpful, thanks!
   / HF Quick Hitch to Bush Hog problem #5
A closer look at your photo makes me think it is a finish mower, not a rotary cutter, and it is meant to float over the ground semi-independent of the hitch. If so, I would leave the floating top link piece where it is, and just lengthen it until it reaches the top link pin on the QH. A welded or bolted extension, or a longer replacement would work.
Bruce
Bruce
Yes, it is a finish mower. I'll give your suggestion a try, thanks!
2014 Aerway Aerator (A55973)
2014 Aerway...
Hays LT1 Tender (A56438)
Hays LT1 Tender...
Year: 2016 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55853)
Year: 2016 Make...
Case 1020 25ft Draper Head (A56438)
Case 1020 25ft...
2022 John Deere 5055E (A60462)
2022 John Deere...
SCREENER (A58214)
SCREENER (A58214)
