3-Point Hitch HF Quick Hitch to Bush Hog problem
/ HF Quick Hitch to Bush Hog problem #1
vulcancowboy
Gold Member
Duncannon, Pennsylvania
Kubota L3400 HST
Just picked up a Harbor Freight quick hitch. I put it on my tractor (Kubota L3400) and I'm having an issue with the top connector. Either the hook on the QH needs to go up, or I need to rework the mower hitch. Am I missing something? Pic attached.
/ HF Quick Hitch to Bush Hog problem #2
Take the top of the hitch apart and reassemble it with the short link behind the A-frame. But it looks like your bottom pins are too far from the top pin. Standard is 18 inches apart and for quick-hitch, 15 inches.
You may need an adapter. Some ideas:
Bruce
/ HF Quick Hitch to Bush Hog problem #3
take bottom bolt out of hook replace top bolt with grade 8 tilt it up and slide you pin in .
BCP, The vertical distance from the CL of the bottom pins to the CL of the top pin is ~ 23". The info you provided is very helpful, thanks!
/ HF Quick Hitch to Bush Hog problem #5
A closer look at your photo makes me think it is a finish mower, not a rotary cutter, and it is meant to float over the ground semi-independent of the hitch. If so, I would leave the floating top link piece where it is, and just lengthen it until it reaches the top link pin on the QH. A welded or bolted extension, or a longer replacement would work.
Bruce
Bruce
Yes, it is a finish mower. I'll give your suggestion a try, thanks!
FRONTIER LR2072-72" LANDSCAPE RAKE (A62130)
FRONTIER...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
2020 INTERNATIONAL MV607 (A58214)
2020 INTERNATIONAL...
JOHN DEERE 7330 PREMIUM TRACTOR (A62130)
JOHN DEERE 7330...
30 Yard Roll Off Dumpster (A61165)
30 Yard Roll Off...
20ft trailer (A61569)
