3-Point Hitch HF Quick Hitch to Bush Hog problem
   / HF Quick Hitch to Bush Hog problem #1
vulcancowboy
Duncannon, Pennsylvania
Kubota L3400 HST
Just picked up a Harbor Freight quick hitch. I put it on my tractor (Kubota L3400) and I'm having an issue with the top connector. Either the hook on the QH needs to go up, or I need to rework the mower hitch. Am I missing something? Pic attached.
   / HF Quick Hitch to Bush Hog problem #2
Take the top of the hitch apart and reassemble it with the short link behind the A-frame. But it looks like your bottom pins are too far from the top pin. Standard is 18 inches apart and for quick-hitch, 15 inches.
You may need an adapter. Some ideas:
Bruce
   / HF Quick Hitch to Bush Hog problem #3
take bottom bolt out of hook replace top bolt with grade 8 tilt it up and slide you pin in .
BCP, The vertical distance from the CL of the bottom pins to the CL of the top pin is ~ 23". The info you provided is very helpful, thanks!
   / HF Quick Hitch to Bush Hog problem #5
A closer look at your photo makes me think it is a finish mower, not a rotary cutter, and it is meant to float over the ground semi-independent of the hitch. If so, I would leave the floating top link piece where it is, and just lengthen it until it reaches the top link pin on the QH. A welded or bolted extension, or a longer replacement would work.
Bruce
Bruce
Yes, it is a finish mower. I'll give your suggestion a try, thanks!
UNUSED FUTURE 30" PALLET FORKS (A57193)
UNUSED FUTURE 30"...
2018 Regal 29OBX 29ft Yacht with 34ft Trailer (A55853)
2018 Regal 29OBX...
2007 Saturn Sky Convertible Coupe (A55853)
2007 Saturn Sky...
2017 Ford F-150 Pickup Truck (A55852)
2017 Ford F-150...
2017 Bobcat S650 High Flow Compact Wheel Loader Skid Steer (A55851)
2017 Bobcat S650...
148in Roll Up Garage Door (A55852)
148in Roll Up...
