3-Point Hitch HF Quick Hitch to Bush Hog problem
   / HF Quick Hitch to Bush Hog problem #1
vulcancowboy
Duncannon, Pennsylvania
Kubota L3400 HST
Just picked up a Harbor Freight quick hitch. I put it on my tractor (Kubota L3400) and I'm having an issue with the top connector. Either the hook on the QH needs to go up, or I need to rework the mower hitch. Am I missing something? Pic attached.
   / HF Quick Hitch to Bush Hog problem #2
Take the top of the hitch apart and reassemble it with the short link behind the A-frame. But it looks like your bottom pins are too far from the top pin. Standard is 18 inches apart and for quick-hitch, 15 inches.
You may need an adapter. Some ideas:
Bruce
   / HF Quick Hitch to Bush Hog problem #3
take bottom bolt out of hook replace top bolt with grade 8 tilt it up and slide you pin in .
BCP, The vertical distance from the CL of the bottom pins to the CL of the top pin is ~ 23". The info you provided is very helpful, thanks!
   / HF Quick Hitch to Bush Hog problem #5
A closer look at your photo makes me think it is a finish mower, not a rotary cutter, and it is meant to float over the ground semi-independent of the hitch. If so, I would leave the floating top link piece where it is, and just lengthen it until it reaches the top link pin on the QH. A welded or bolted extension, or a longer replacement would work.
Bruce
Bruce
Yes, it is a finish mower. I'll give your suggestion a try, thanks!
(INOP) JOHN DEERE 544 AA WHEEL LOADER (A60430)
(INOP) JOHN DEERE...
CFG Industrail MX15RX (A53317)
CFG Industrail...
2011 KOMATSU D65PX-16 CRAWLER DOZER (A60429)
2011 KOMATSU...
John Deere 5103 (A53317)
John Deere 5103...
JCB 509-23TC TOOL CARRIER TELESCOPIC FORKLIFT (A60429)
JCB 509-23TC TOOL...
2011 DOOSAN G40 GENERATOR (A55745)
2011 DOOSAN G40...
