Help with window sizing..
/ Help with window sizing.. #1
thatguy
Elite Member
Bedford, VA
John Deere 2320
OK, Im way confused and cant remember how to decipher a window size of '2860' (as specified in the blueprints)... I am pretty sure it isnt 28" wide x 60" tall.. and Im thinking it is 2' 8" x 6' 0"...
Am I even close?
thanks
Brian
/ Help with window sizing.. #2
Bases upon my 3D drawing program it would be 2' 8" x 6' 0". /forums/images/graemlins/confused.gif
/ Help with window sizing.. #3
32 inches tall by 72 inches long.....Measure and see if it's this. If it is then 2'8" x 6 is right
/ Help with window sizing.. #4
28x60 is pronounce two eight by six oh
It means the window is two feet, eight inces wide and six feet tall.
Eddie
/ Help with window sizing.. #5
Some window manufacturer's use a differenet numbering system for different types. Marvin uses the single sash size to indicate a double hung...it has no relation ( numerically ) to the rough opening of the entire unit. Doors are always listed width ( feet inch ) x height ( feet inch ) like stated earlier two eight is 2'-8".
Be careful since each window style and each manufacturer have different roughing dimensions.
/ Help with window sizing.. #6
Years ago I drew plans for a house and had some windows dimensioned 6' 0".
The carpenter framed the openings 60" and had too tear out and reframe.
Don't know why he didn't frame the 3'0" doors 30 inches. /forums/images/graemlins/confused.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/tongue.gif
/ Help with window sizing.. #7
FINALLY! A question for us carpenters!
As mentioned in several post's, feet+inches, width then highth, "double hung" will indicate size of ONE sash. Manufacturers will furnish rough opening size upon request.
Doors use same measurements (wide X tall) feet then inches. Rough opening for doors is 3" wider and 2" taller than door size. Remember that door opening should be determined "AFF" (Above finished floor) Should you be laying 3/4" hardwood floor later, opening needs to be 3/4" higher to compensate.
/ Help with window sizing.. #8
Hi Brian,
I believe these windows are Anderson, double hung, vinyl clad, 28x50. 32" by 5ft. If this helps at all. The valances I made a few years ago to accomodate my wifes looped curtains. /forums/images/graemlins/grin.gif
scotty Windows
EZ Trail 3400 (A63688)
2006 Ford F-150 Ext Cab Pickup Truck (A61573)
2006 Ford F-150...
2005 Peterbilt 357 Tri-Axle Dump Truck (A61573)
2005 Peterbilt 357...
2017 Case CX145D (A60462)
2017 Case CX145D...
Tufline PT 12' Box Blade (A64119)
Tufline PT 12' Box...
2016 Ford Fusion S Sedan (A59231)
2016 Ford Fusion S...
