ruffdog
Super Star Member
- Joined
- Dec 31, 2011
- Messages
- 12,727
- Location
- America's Dairyland
- Tractor
- Bobcat Toolcat 5610G, Deere X744, Cub Cadet IH 982
Wow...1011 steel must be horribly gummy to machine.
So, there's nothing in Zinc that would impart brittleness to mild steel when welded?
My mild steel wasn't as mild as I thought?
Thank you. It's been a very long time since I welded on the zinc covered straps (I think they were used as braces at the tops of utility poles) and I can't remember exactly how soft they were before being welded.SNIP/So plating can cause problems but not sure if it is yours.
Very interesting John. Thanks for taking to time to explain. I have a question on mild steel if that is OK. If you crudely heat a piece to dull red or maybe even orangey/yellow with your torch so that it bends/deforms easily is there any difference in the end product properties if it is left to air cool or is quenched in water?
gg
The time sensitive parts from the point of view of the heat testing are the initial heat up followed by the quick quench. You can let the part sit around for days after that before heating it back up to temper the blade.
The initial heat up and quench can be dramatic (relatively speaking): glowing steel followed by a dunk in something cold. The reheat is boring: just warm it up, probably well below the temperature where the steel glows. Maybe they don't show it because it doesn't make for good TV?
A very small subset of "blacksmiths" on the show will reheat their blades to "normalize" them- but there is no re-quenching associated with this, just using an OA torch/rosebud, and air-cooling- these blades seem to withstand testing somewhat better than the other blades.
