Grappling fun - A Picture Thread....
/ Grappling fun - A Picture Thread.... #1,741
Nice! If you cut that in quarters I'd be able to roll them around with my little machine. :laughing:
I don't think I can cut it, would ruin a lot of chains, unless I had a large bandsaw. That log has been setting on the ground covered with coyote brush and poison oak for about 35 year its like iron
/ Grappling fun - A Picture Thread.... #1,742
Re: Grappling fun - A Picture Thread....A quick make **** jib crane for my grapple
I bought a used poly water tank 10' 2" dia x 76" from a neighbor 3 miles away with the understanding that the pump & well service were to load it on to my trailer, as they are equipped with a boom crane on their truck. I arrived with my trailer and they said the tank won't fit on my trailer, I had taken my wider flat bed trailer 78 " width between the sides, the crew said "Oh the tank won't fit its to wide. I explained that I had measured it and it would fit. I had planned to give them 50 bucks for their trouble even though it was arranged up front as part of the job by my neighbor. They just wanted to cut up old tank with a sawzall. I didn't want to argue with them. I returned next day with my tractor and a simple (rube goldburg) jib crane. I found this old equipment rack in my metal scrap pile & secured it with chains to my grapple and away I went. I just had enough reach to load the tank other wise I would have gone to plan B. Anyway pictures of Grapple with Jib crane & the tank. I am going to send the pic to the crew that said it would not fit.
/ Grappling fun - A Picture Thread.... #1,744
^^^ X2. It must have been interesting handling that !
gg
/ Grappling fun - A Picture Thread.... #1,745
Storm damage clean up after a big windstorm in the fall of 2017:
/ Grappling fun - A Picture Thread.... #1,746
gg
It wasn't bad, Slow & easy, I was just hoping that it was long enough to allow me some slack in the chain once I got it lifted up on the trailer to remove the chain (if it were to long loader might not lift the 900 lb tank) fortunately all worked well. I could have done some calc's to know for sure but it all looked right and besides it was just sitting in my scrap pile. I didn't want to make a bigger job out of it by building something like this. -->fullsizeoutput_2780 (1).jpeg
/ Grappling fun - A Picture Thread.... #1,747
Finally got my EA "Wicked 60" grapple on and working. Of course I was broke after buying the tractor and couldn't afford the 3rd Function valve and switch so I had to run the hoses back to the rear remotes. This will work just fine for the time being.
/ Grappling fun - A Picture Thread.... #1,748
Very nice !!! Looks intimidating! Congratulations.
/ Grappling fun - A Picture Thread.... #1,749
You should have gone bigger on the grapple^^
/ Grappling fun - A Picture Thread.... #1,751
I got a little one.
/ Grappling fun - A Picture Thread.... #1,752
It wasn't bad, Slow & easy, I was just hoping that it was long enough to allow me some slack in the chain once I got it lifted up on the trailer to remove the chain (if it were to long loader might not lift the 900 lb tank) fortunately all worked well. I could have done some calc's to know for sure but it all looked right and besides it was just sitting in my scrap pile. I didn't want to make a bigger job out of it by building something like this. -->View attachment 568784
I built something Similar to this with 4 X 4 X 3/16 5ft. long Outer Tube Steel and 3 1/2 X 3 1/2 X 3/16 6 ft. long inner Tube Steel for my MX5800 telescopes out the 10 ft from my quick connect front end. I also added a nice Swivel Hook with a shackle that can be moved between the 4 in and the and the 3 1/2 tube or removed all together.
Works great just have to be conscientious and careful when using it.
/ Grappling fun - A Picture Thread.... #1,754
First timer. Would you be able to send me pictures of your creation (Jib Crane) "just have to be conscientious and careful when using it" one has to always be aware when using any equipt as things can go wrong fast. Thanks Bill
/ Grappling fun - A Picture Thread.... #1,756
I will try and take some pic,s this afternoon and if I can figure out how to post them I will.
/ Grappling fun - A Picture Thread.... #1,759
The "dirty" picture is from this spring when I was splitting my wood. I bring the wood down from where I had cut it to length to my building. I will then split it and stack it inside the building. This my wood splitting setup, tractor, splitter on the 3 pt, wood wagon and grapple. I load the wagon with the grapple. No more hand loading the bucket. I put extra weight on the tractor/ grapple because I am coming down a slight grade that sometimes pushes me and the tractor around. As you can see is was wet at the time and the road was greasy. I would rather have the extra weight on the tractor versus the wagon. The other pictures are from about a month ago when the tractor is set up for mowing. My neighbor had some wood laying around for a couple of years that he did not want. It was an easy pick so I just put on the grapple and took it home. There was probably 1.5 cords in all. Just some grapple fun time pics. Later.
2008 Ford F-250 Ext. Cab Pickup Truck (A61573)
2008 Ford F-250...
Snap-On Southern Thunder Edition 24-drawer tool box (A63689)
Snap-On Southern...
2002 CHEVROLET 3500 FLATBED TRUCK (A60430)
2002 CHEVROLET...
2011 Dodge Ram 1500 Crew Cab Pickup Truck (A61573)
2011 Dodge Ram...
2007 Toyota RAV4 SUV (A61574)
2007 Toyota RAV4...
2716SFL (A61567)
2716SFL (A61567)
