Grappling fun - A Picture Thread....
/ Grappling fun - A Picture Thread.... #1,221
Trimmed the trees and tore up some brush. What a difference a grapple makes.
/ Grappling fun - A Picture Thread.... #1,223
I've never heard of a rear mounted "root rake". I've tried to use my landscape rake like you did but it is mostly a fruitless waste of time to try collecting sticks and the like that way. The debris just clogs up the rake and the rake jumps over it or digs up the turf. Big mess.
This is what comes to mind for a CUT rear attachment for getting roots out of the ground.
Bruce
/ Grappling fun - A Picture Thread.... #1,224
Bruce
Interesting. Not a very common implement. I guess I would just use my box blade with tines extended and without the main blade in contact with the soil to do the same thing. That or just use a root grapple. I am having a hard time envisioning a large area with surface roots that need ripping out. I certainly have fields where I know there are briar roots etc under the turf but I deal with them by mowing regularly so they eventually die off. Trouble with trying to rip out the roots is that if you leave just a fragment of root behind some plants will just regrow anyways.
/ Grappling fun - A Picture Thread.... #1,225
The difference between those and a box blade is the scarifiers can go much deeper, if your tractor can pull it.
I like the one with the piggyback rake, if you can use either one by adjusting the top link instead of having to change implements.
Bruce
/ Grappling fun - A Picture Thread.... #1,226
/ Grappling fun - A Picture Thread.... #1,227
I had a thread about this a couple weeks ago.
The largest load I've picked up with tractor and grapple, a large dead hickory trunk:
IMG_20170320_160712928 (Large).jpgIMG_20170320_160707595_HDR (Large).jpgIMG_20170320_160738961 (Large).jpgIMG_20170320_160730556 (Large).jpgIMG_20170320_160800392 (Large).jpg
/ Grappling fun - A Picture Thread.... #1,228
Nice. Are you just using a box blade as ballast or are your tires filled? What grapple is that? Looks like a good match.
/ Grappling fun - A Picture Thread.... #1,229
IT,
Yes the BB is my go-to ballast. It weighs 675 lbs, has 410 lb concrete, steel and lead weight block on the end that also holds my Ratchet Rake, my tires are filled and I have 500 lbs of concrete, steel and lead wheel weights. That trunk came very close to lifting my rear tires!
The 48" grapple I got from Skid Steer Attachment Depot, a local dealer in Huntsville AL. The only problem I have with it is the male end of the FF connectors on the tractor side always has to be dissembled to connect the grapple. What a PIA.
/ Grappling fun - A Picture Thread.... #1,230
Is the lid up or down when disconnected?
2016 Yanmar Vio45 (A60462)
2016 Yanmar Vio45...
2020 INTERNATIONAL TANDEM AXLE SLEEPER (A58017)
2020 INTERNATIONAL...
2015 Peterbilt Dump Truck (A55973)
2015 Peterbilt...
2018 MACK CXU (PINNACLE) (A60736)
2018 MACK CXU...
2019 DRAGON ESP 150BBL ALUMINUM (A60736)
2019 DRAGON ESP...
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A58216)
2013 ORTEQ ENERGY...
