Grapple Grapples Galore
/ Grapples Galore #61
flINTLOCK said:
Island, out of curiosity, what is your loader capacity. My TC40 DA with 17LA rated about 1500 # I think. It seems from the stuff you can grapple, yours might be higher!!
Less than yours. 1070lbs at the pivot pins for lift to full height. My loader is the Kioti KL120 on a CK20 tractor. You can do a lot with a 21hp tractor.;)
Brush doesn't weigh that much it's just bulky. Also, some of the photos I show of big logs etc are not lifted to full height obviously as I am traveling with them. Not sure I could lift the bigger logs to full height but I can lift them to a safe traveling height and move them.
/ Grapples Galore
It appears to me that the brush crusher actually has three teeth on each grabber instead of two. It has two together then one single. That way they can mesh together to overlap. I agree that it seems to be a very limited and specialized piece of equipment. Personally, I wouldn't pay more than a couple hundred dollars for one. I just wouldn't be able to use it like a brush grapple rake.
I ordered my Markham Welding HD grapple rake this morning. I cannot wait until it arrives. Unfortunately it will be next week before it ships out due to inventory.
/ Grapples Galore #63
Nice looking grapple. Assume you got the 72 incher? What do you plan to use it for?
/ Grapples Galore
I plan to use it for grappling. Just kidding. I have literally tons of moderate sized brush piles all over the place that I need to gather up and place in one central area. I also have much more potential brush piles from the fence lines I need to clear. I will also use it to pull up about a million tree saplings (2-3") around the fence lines. I may be able to use it to yank out all the fence posts I plan to. Of course, a 4-in-1 bucket would be better for that but I decided to go with a brush grapple. If I'm not able to actually pull the fence posts out with the grapple I'll at least use it to gather up all the fence posts I have laying all around.
I actually got the 66 incher. From reading the informative posts by IslandTractor I have begun to realize that wider is not always better in a brush grapple. The only reason I didn't go with the 60" model is because I thought it may look a little bit "funny" since it would be more narrow than my fronts. I think the 66" would look aesthetically correct on that size tractor. Of course so would a 72" but I think the extra weight (and cost) would be a big of a negative factor. Now if I were going to get a 4-in-1 bucket like you did I'd definately go with the 72" model.
I may have to post some pics when I get it.
/ Grapples Galore #65
Should work out fine for you. We need to see pics of it in action when you get it. Looks to be quite strong which is what you need for your tractor.
/ Grapples Galore
I'm sure I'll post some pics. It does look pretty heavy-duty, hence the name. They do have a light duty model which is not listed on the website. Melissa at Markhamwelding had mentioned it to me in an email stating that it may be more suitable for a tractor. She sent me some pictures. It looks almost identical to the Millonzi light-duty grapple. When I told her that my tractor was 68hp and 4wd she told me that I definately should get the HD model. They don't recommend the LD model for 4WD tractors over 40hp. There is a good chance the power of the tractor will push the grapple too much and cause it to be damaged (ie. bent to pieces). I guess with a battle between a powerful tractor, light-duty grapple, and stubborn brush the grapple loses. In a battle between a powerful tractor, heavy-duty grapple, and stubborn brush the brush loses. IslandTractor--I hope you don't take any offense. You know how to use your lightweight grapple and small, spunky little tractor to tackle the most monstrous brush like a pro.
Who wins the battle between a powerful tractor, a heavy-duty 4-in-1 bucket, and a big rock?:D
/ Grapples Galore #67
Can you post the pictures she sent you, or e-mail them to me?
/ Grapples Galore
Here you go: Markham Welding Light-Duty Grapple Rake
I was quoted $1100 for the 66" model.
/ Grapples Galore #69
I just ordered the Bodozer today myself. I liked the way it closes down real tight so as to be able grab something small if needed. I ordered it in 5' as to save on weight. My bucket on the JD520 loader is 6' but I can't see where the extra foot will do anything for me but add weight to the implement. Anyone have any experience with these to steer me larger. Its not to late to have them ship a 6' model. The loader is on a JD5400 60HP PTO tractor.
/ Grapples Galore #70
There are several ways you can damage a grapple but I would not be concerned about damaging any grapple while going after brush with even a big CUT.
First, a big heavy tractor with lots of momentum driving a grapple through soil in "root grapple" mode could hit a big rock or stump and cause the whole tractor to come to a stop or worse. Worse would be hitting the immovable object other than dead center so the FEL/grapple was torqued to one side with considerable force. That might damage either the grapple or the FEL. Frankly I'd rather damage the grapple in that setting but I suspect it would be the FEL that suffered most.
Second, a monstrous capacity FEL (MUCH bigger than what Kubota sells for L or M class) could generate enough lifting force to distort grapple teeth. I see that WR Long rates their lighter duty grapple up to 3000lbs lift capacity so I don't think that is a practical issue for CUT owners but might be for big skid steers or big TLBs.
Third, you can do something that the grapple was not designed for such as place a lateral load on it. You could do that with a smaller tractor too so size is not a real issue there. Also, that same lateral load would just as likely injure the FEL itself.
I think that manufacturers are likely to recommend heavier duty (more expensive) options especially since they make the sale anyway and don't need to worry that you'll find a way to damage the goods. Realistically, cleaning up brush is such light duty work for any grapple that it is hard to imagine "breaking" a grapple while clearing brush unless the operator was abusive. Charging a stump like a bull to dislodge it will likely damage equipment unless you are driving a bulldozer. Bulldozers don't have FEL arms like tractors. They are short and stubby so cannot twist easily. I'd imagine that using a root grapple as a bulldozer might would likely hurt the FEL at least as likely as the light duty grapple.
Like most tools (hammers and bulldozers excepted) grapples are designed to be used properly. The proper use of a grapple is to grab on to something so that the FEL can lift/curl the object. No CUT FEL can curl or lift more than 3000lbs which is just not going to damage 3/8th x 4 inch tines ganged in groups of six or seven. Grapples, even those with weird names like "root grapple" are not designed to be used like 3PT subsoilers or bulldozers where there might be a sudden shock load from hitting a rock or stump. When using a root grapple to cut roots it is generally done just as you would dig with a bucket. You'd presumably put the bucket down then move forward rather than dropping the bucket while moving at high speed. I don't see how a grapple in subsurface mode would be injured any more than a bucket in the same situation. The momentum of a big CUT (eg orange M class) is probably not much more than double that of a smaller CUT (eg the other orange CK class) as the weight is not more than double (I cannot recall my physics right now but I recall momentum is a linear function). I have stalled my tractor on a number of occasions while driving the grapple against a stump with no harm done.
Having defended the light duty grapple, it is fair to add that I don't see any major downside to the heavier duty grapple for a CUT/FLE with a 2000lb plus lift capacity except acquisition cost. Even the added grapple weight will leave you with plenty of lift capacity as brush is simply not that heavy. Logs are heavy but CUT owners are not commercial operators trying to move three or four big logs at a time fifty times a day so that is not a practical concern either. I've never pulled a fence post but I imagine you'd essentially be trying to lift them out of the ground. Unless set in concrete :)eek: ) you'd just need to overcome friction of the post walls to pull them straight up so I'd imagine the loss of 300-400lbs of lift capacity with a heavier grapple would not be important there either.
To reiterate my main points: heavy duty grapples are built for big skid steers. I doubt even the biggest CUT FEL requires the heavier duty construction and the major downside to consider is whether the added weight will interfer with your intended use.
/ Grapples Galore
:D :D
All good points. I agree with you. The only one I don't agree with in this specific context is that Markham would try to sell the larger grapple just to make the sale. They seem to be extremely honest and are looking out for the best interest of their customers. They don't warranty their light-duty grapples, just the hydraulics. They have a 1-year warranty on the heavy-duty grapple. By the way, the lift capacity of the M7040 is over 2,500 lbs.
So, all of your points are valid. I just wanted to put in a good word for Markham specifically.
By the way, momentum = mass x velocity. If I recall correctly. So it is a linear function.
/ Grapples Galore #72
Momentum = mass x velocity(squared)
linear for mass, geometric for velocity.
/ Grapples Galore #73
What's up Doc?
High school Physics teaches us otherwise.
kinetic energy = 1/2 x mass x velocity x velocity
Respectfully,
LogChain
/ Grapples Galore #74
:eek: Of course you're right - that's why I got all "C"s in Physics!
/ Grapples Galore #75
Doc, don't feel bad, I flunked every class first semester until I found out I was highlighting with a black magic marker. :)
/ Grapples Galore #76
I did not mean the comment as a slam on Markham. I have one of their toothbars and they are a great company. My point is more that if a customer shows that he is "wondering" about the adequacy of a light duty implement it would be natural for a sales person to simply bow to the customers perceived need for something bigger. I betcha that Markham sells the vast majority of their grapples to skid steer owners and that they have relatively little experience with CUTs (for grapples). That could be a factor as a 68hp skid steer would be quite a brute compared to an M7040 at least with regard to FEL power. I haven't looked up the lift capacity of skid steers but I imagine that 2500lbs of lift would be a smaller (HP wise) skid steer, maybe something in the 30-40hp diesel range. If the Markham sales people are more familiar with skid steers they might well advocate the heavier duty grapple based on such a (mistaken) belief that tractor FELs are equivalent to skid steers and would therefore require similar duty implements.
/ Grapples Galore #77
With some designs of light-duty grapples it is possible to bend them if you don't apply the force in a straight line -- so be careful of pulling sideways with the teeth, or carrying heavy loads pinched with only one tooth...
I bent one of the outside teeth (or fingers or whatever you call them) on my PT's grapple bucket trying to move a big log sideways by articulating the tractor. Note that these teeth have no lateral reinforcement in the last 12" - 14" or so...
http://loonlanding.info/2_IMG_0053.JPG
/ Grapples Galore #78
No lateral reinforcement for the last foot or so will certainly cause problems when you do put a lateral force on the teeth. Most grapples seem to have more reinforcement than yours. I think mine has reinforcement up to about 5 inches or so. Still, the type of operation you describe is exactly the kind of lateral stress that no grapple is really designed for. They are engineered strictly for up and down, forwards and backwards forces, not lateral. Then again, that is exactly the same as an FEL so almost anything that could damage a grapple could also damage or torque FEL arms.
/ Grapples Galore
I think you are completely right on target there.
They initially steered me toward the light-duty grapple when they found out I would be using it on a tractor, but then told me I'd likely be better off with a heavy-duty based on my tractor specs. But yesterday, when I was ordering it, Melissa said, "Now you're planning on putting this on a tractor, right?" She was wanting to make sure the universal skid steer attachment would work without an adaptor and that I had the hydraulics to run a third function. But that did give me the impression that the vast majority of their business goes towards skid steers owners.
I don't know. It's all a moot point to me now anyway. I'm glad I ordered what I did and I'll be glad when it gets here.:D
/ Grapples Galore #80
:rolleyes:
Exactly, now you will be a GRAPPLE owner and really start to have fun.:D :D :D I expect you to get that silly bucket off your avatar photo and replace it with a photo of a real tool soon.
Just to double check, make sure that either Markham equips you with the appropriate hoses/couplers or that your dealer gets you the correct stuff to hook it up. Nothing is more frustrating than a brand new grapple with no way to make the hydraulic connections.:eek:
2009 EZ-GO GAS GOLF CART (A63276)
2009 EZ-GO GAS...
2015 RAM 4500 HD 4x4 Service Truck (A62613)
2015 RAM 4500 HD...
Wolverine Brush Cutter BC-13-72W Skid Steer Mount  (A62679)
Wolverine Brush...
New/Unused 3 Point Hitch with Ball/Flat Hitch (A65583)
New/Unused 3 Point...
Landhonor 72"Wx100L"x71"H, 6'x8' Galvanized Shed (A62679)
Landhonor...
2004 CAT 247B SKID STEER (INOPERABLE) (A65643)
2004 CAT 247B SKID...
