Grapple Grapples Galore
/ Grapples Galore
m7040 said:
The point is you need to think about your use of it and make the selection based on that.
Good point. I am kinda thinkin' that my best bet would be a set-up like you have with a 4-in-1 bucket and then an attachable grapple to a regular bucket. The only thing better would be having a regular bucket, a dedicated grapple, and a 4-in-1 bucket. But that may be a bit over-the-top.
/ Grapples Galore #42
How about a grapple on a 4 in 1 bucket, now that could be :cool:, but very very costly. You would have to have a 2nd function on you 3rd function valve.:D
/ Grapples Galore #43
I could see the 4n1 plus the full grapple but if you had that why would you need a regular bucket? I'm thinking about a 4n1 mostly for its "dozer" and scraper capabilities in relatively small landscaping tasks like cleaning up after pulling out a stump. It would cross over a little with the grapple but really the two would complement each other nicely. That's what I keep telling myself anyways as I contemplate springing for the 4n1. Of course this would make the most sense for someone with a QA adapter. Hey, I have a QA adapter....I'll add that fact to the plus column.
/ Grapples Galore #44
I don't disagree that the more an attacment is designed for a purpose, the better it can be for that. But bucket grapples are very useful. It also allows for material removal that you want to get rid of which would/might sift through a grapple bucket. I guess it depends what you want and what you're willing to put up with.
In my use, I could not justify a dedicated grapple and elected to go with the bucket add on grapple. The real advantage of a true grapple bucket (to me) was moving big logs that stuck out the end, carrying them closer to the pivots. I did not really need that since my fel has 2,500lb capacity. As far as brush goes, or dead stuff, my grapple add on crushes the brush into my bucket anyway, so the sides do not become compomising at that point. The bucket is a great help for me instead of the sift feature, as I move a lot of crud, broken branches, rocks along with the brush piles. If this stuff filtered through, I'd have to put a bucket on and pick it up afterwords in my case.
Just another view on the subject.
Here are some pictures of my bucket add on grapple in use.
To put it in perspective, my 55hp Kama is pretty big pushing 7,500lbs loaded.
This is one before the add on grapple with only a toothbar. So it all depends on what you want to do and what you expect.
/ Grapples Galore
Hmmm. Maybe I could get a 4-in-1 bucket and attach an add-on grapple. Then power either the grapple arm or bucket opening from the 3rd function valve and the other one from a rear remote. Hmmm.:rolleyes: That would be like some sort of complex sci-fi cyborg appendage on the end of the loader arms.:D
/ Grapples Galore #46
Glowplug said:
Hmmm. Maybe I could get a 4-in-1 bucket and attach an add-on grapple. Hmmm.:rolleyes: That would be like some sort of complex sci-fi cyborg appendage on the end of the loader arms.:D
That was my whole idea.:)
/ Grapples Galore #47
That sounds like a nice all in one solution (5n1?) but I don't know if anyone has done that successfully. For starters you'd need two sets of extra hydraulics for the bucket/grapple. That is doable but expensive and cumbersome. Another concern would be that the grapple arm would interfere with the front jaw of the 4n1. At the very least you would need to coordinate their use so you did not try to open the front bucket jaw without first opening the grapple to avoid a collision. Those hydraulics are pretty powerful so you might cause damage to either the bucket front or the grapple arm if you forgot to keep them separated.
I'd also worry a bit about the weight of the 4n1 plus grapple arm. I imagine a decent grapple arm and mounting adds about a hundred pounds to the weight of the already heavy (typically 600lbs+) 4n1 buckets. For bigger FELs that would not be a big deal but for <40hp tractor/FEL that would be taking a pretty big bite out of your lift capacity.
If I were to start from scratch I'd get a QA adapter, a 4n1 and a lightweight root grapple. It would be a bit more expensive (about $300-400 extra for a 48" grapple) than a 5n1 but would be overall much more flexible.
I like multifunction tools as much as the next guy but at some point it makes sense to have "the right tool for the job".
/ Grapples Galore
I think I'm gonna go ahead and order a Markham Welding root grapple (66") and a toothbar today. I know I've said that before but if I can find the time before 5pm I believe I'll go ahead and do it. I had considered the 60" grapple but I think the 66" would look more balanced with my big tractor. It only would add about 25lbs too. So I don't think that would adversely affect my net lifting capacity. I couldn't imagine lifting a ton of brush. I guess I could imagine lifting a 2,000lb rock though. But the weather's supposed to be in the single digits early next week. So I may have my dealer pick up my tractor and install the extra hydraulics and get the grapple on the way since I won't be able to "play" outside.
/ Grapples Galore #50
I just had a Piranha delivered last week. WOW what a well built piece of equipment. I took it to the dealer and had him install the bobcat style quick attach, and got it home to play. For be no bucket could do the job of a root/rock grappler. With a bucket every time I pick up anything I get a little to a lot of sand and when I dump that in the trailer it adds up to a ton or so a load. Since I pay to dump by the ton, it adds up. Now when I hit the pile, I ONLY get brush, logs, palm leaves etc, NO SAND. It’s great to see all the sand drain from the load, before I dump.
The quality was so good with the Piranha, that I quickly ordered a “Turkey bucket” with quick attach, and Tree boom.
Yes 4 in ones do have their place, but for me where was this thing for the last few years. Weight about 650lb, on a Kubota L4310
/ Grapples Galore #51
/ Grapples Galore #52
Turbys_1700 said:
A grapple that I am impressed with is from Westendorf. I've attached a link. The two arms work independently of each other. For brush I think that this is a great option.
Two grapple arms make no difference at all for brush. If you are picking up conical object or construction debris maybe but for brush it really is zero advantage and just adds weight and expense.
/ Grapples Galore #53
The advantage of the Westendorf "Brush Crusher" is that the jaws operate on the FELs curl hydraulic circuit, and don't require additional hydraulics.
/ Grapples Galore #54
Then how does one curl the "Brush Crusher"? You need to be able to curl/uncurl a grapple in order to pivot the jaws over the top of a pile or stump before closing the jaws. Otherwise you are limited to a passive straight forward scooping motion (e.g. float position) which would certainly work for some things but would be pretty limiting.
If you cannot curl you cannot pick up things like this:
/ Grapples Galore #55
Absolutely... you can pick about twice as much brush if you come down on it from the top. If it is a tall pile, use downpressure with your bucket to crush the brush down, then close the grapple to pinch a big bite...
If it is looser stuff, like slash from treetops, I like to tilt the front of the bucket (and toothbar) down about 30 degrees, then push into the pile until I've filled the entire bucket and grapple (with the grapple open) and then curl the bucket trapping the brush underneath it. Finally, close the grapple and pinch all this together into the bucket. Then lift straight up, with the grapple still pointed toward the ground. I can get about twice as much brush into the bucket using this technique. Plus, with the grapple pointed down to the ground, it moves the whole load back closer to the tractor (and lift cylinders and pivot points) and I can pick up noticeably more weight...
/ Grapples Galore #56
KentT said:
If it is looser stuff, like slash from treetops, I like to tilt the front of the bucket (and toothbar) down about 30 degrees, then push into the pile until I've filled the entire bucket and grapple (with the grapple open) and then curl the bucket trapping the brush underneath it. Finally, close the grapple and pinch all this together into the bucket. Then lift straight up, with the grapple still pointed toward the ground. .
That is exactly what I do. The only tricky part, which really just requires practice, is rolling the top of the grapple over the pile as you slowly move forward. That manuver helps to crush the brush into the grapple. Just driving forward without rolling the grapple over the top will just push the pile along the ground rather than trap it in the grapple.
/ Grapples Galore
Nice techniques guys.
It appears as though the Westendorf "Brush Crusher" is a totally different sort of beast. It looks like it works like two grappling hooks. You just come straight down on the pile with the hooks open, then close them, and lift the pile up. Very much like those little games where you try to use a hook crane to grab prizes, stuffed animals, etc. We all know how well that works. Of course, the "Brush Crusher" is designed to actually work instead of frustrate, tease, and amuse. I don't know if I'd like that type of setup though.
/ Grapples Galore #58
I've looked at the photos of the "brush crusher" and it is very much a specialty device optomized for picking up whole logs. It has only two teeth each on upper and lower jaws separated by 5 feet so it can easily pick up a log but smaller brush would fall right through. You can order "finishing teeth" for the bottom jaw which would accomplish not much as there is still no way to hold the brush in place with the top teeth. This thing is very much purpose built to handle full trees or large sized slash and is nowhere near as versatile as a regular root grapple. Additionally, it costs way more than equivalent sized root grapples and four to five times as much as the sort of light duty grapple I have. The Westendorf "Brush Crusher" may have a legitimate role in a full time logging operation but would be next to worthless as a general purpose grapple.
/ Grapples Galore #59
Island, out of curiosity, what is your loader capacity. My TC40 DA with 17LA rated about 1500 # I think. It seems from the stuff you can grapple, yours might be higher!!
/ Grapples Galore #60
Westendorf makes several versions of the Brush Crusher. The simplest, (I don't remember model numbers) uses the "dump" function of your loader to open and close the claws of the implement. You lose the ability to both curl and open and close. They also make though, a version that requires a 3rd hydraulic function similar to the grapples made by Anbo, Bodozer, etc. . .These models have their own cylinders and require a 3rd function. I considered the Brush Crusher before eventually buying the BoDozer. I have a large Ford tractor with Westendorf's "Quick Attach" system that could have used their most basic Brush Crusher. I wanted to use the grapple however on my Kubota L5030 that has the Skidster Style quick attach system. The only model in Westendorf's line that was set up for the skidster system is the BC7000 which has its own cyclinders and requires the 3rd hydraulic function. After using the BoDozer grapple, I agree that the ability to open the grapple and come down on brush from above is a valuable option. The most basic Westendorf won't do that.
2020 CATERPILLAR 289D3 SKID STEER (A65053)
2020 CATERPILLAR...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
2015 Dodge Charger Sedan (A61574)
2015 Dodge Charger...
KUBOTA BX23SLB-R-1 TRACTOR (A62129)
KUBOTA BX23SLB-R-1...
New/Unused Landhonor Toolbox with 24 Ratchet Straps (A65583)
New/Unused...
CATERPILLAR 314EL CR EXCAVATOR (A64277)
CATERPILLAR 314EL...
