Good morning!!!!
   / Good morning!!!! #102,401
Mostly
The shunts provide the means to meter various values. How much output from Radian inverters or charge from their chargers. Charge provided by PV via the Charge Controller. I will use the 3rd to meter the charge provider by my FX chargers. My understanding is a shunt provides a known resistance, making measurementspossibe
Oh, I assumed (we know what that means) you meant a shunt trip coil, that gets energized to trip a breaker. Hence my comments about manual reset of breakers. Similar in nature to a UV coil (undervoltage) except works kind of opposite. They are used as lockouts.
A 1 line is the power flow, not controls. I did not know breaker values for FX but put in breaker symbols where one should be.
Hope you get it working soon.
   / Good morning!!!! #102,402
Good Morning.
Holy smoke, we are having a heatwave! 33°F and going to a high of 39. Wind SE 5 mph. Rain!
This is the way last winter started off.
I have a town run today and I think the dump, too.
Anodes for water tank are ordered, $34.oo + tax each. They should be in on Tuesday. The tank only takes one, but I figured that if they go every three years, I will have a spare readily available. I will save the water tank nightmare until Tuesday/Wednesday.
Have a good day all
   / Good morning!!!! #102,403
Good morning. No rain yet, but it sure is dull this morning.
Thanks for all the lantern suggestions. I had a quick look and discovered that my brad nailer, or at least it's battery, will power a light for quite a long time.
Ron, if I lived closer, I would have to come and check your claim on a slight excess of cinnamon :licking:
Speaking of blazing, this story came out yesterday, with photos showing even more heavily damaged power tower rings and hanger hooks than the photos I showed previously here. One ring is worn through entirely, and another hook is just barely intact.
Yikes, that must be a lawyers dream and a nightmare for everyone else.
You know how superstitious folk will cross the street rather than walk under a ladder, in your area they must be crossing the state to avoid passing under PGE power lines.
   / Good morning!!!! #102,404
Billy, I would never try pull start 100 times. After about four pulls would check plug for gas then spark check if plug is wet. If plug is dry remove air cleaner and few drops of gas into intake or carb.
Mostly, you have to remember Billy is a bow hunter and they take every opportunity to build up those biceps. Bet he fills it with stale fuel on purpose and doesn't even flick the switch to "On" for the first 100 pulls :laughing:
   / Good morning!!!! #102,405
33 high of 65 today rain moves in tomorrow thru Saturday
Prayers for all
   / Good morning!!!! #102,407
Poured first cup of coffee. 36° with cloudy skies this morning. Heading to 50° with rain and wind. Need to buy more apples and cinnamon. Yesterday dehydrating will not last long. Back to dentist today. Hygienist had to have six stitches in injured finger. No other plans. Hope that rain and wind knock down some of the leaves left on trees. Then I can get out and mulch them up. This will allow me to put snow blower on mower.
Been having a difference of opinion with Sassy. She has decided that doing #2 outside is not what she wants to do. At least she does do it in the mudroom. Looks like I will be taking her to a dog training class like Don took Whipper to. Maybe I need training?
Woke up this morning with front flood light on. Deer must be hungry. This one was chewing on Burning Bush. Michigan has banned all feeding of deer because of CWD.
Looking, I forgot about the anode rod. Have not check mine in years. I need to put it on the list.
David, like your solar/generator control upgrades. My mind has gone into retirement. So I have not been able to follow it completely. Keep the info coming. Nice truck.
RNG, sure hope they get the power maintenance problems in CA under control soon.
Wngsprd, I have had engines that would not start easily. Most could to started by removing plug and putting a cap full of gas down the hole. Unless plug was covered with fuel. Which usually means bad ignition/spark. I would never pull on a starter cord 100+ times. My arm would start screaming after 3 pulls.
LS, hope they come up with a plan for your knee soon.
Good Morning All.
   / Good morning!!!! #102,408
35 headed to 55, I’d like to get some seat time but we will see. 90 % chance of rain tomorrow.
Hope your day goes well. Prayers.
   / Good morning!!!! #102,409
32° and frosty, going to 50° sun up now.
Wind was chilly yesterday. Got the trim pieces to work on camper, but too chilly out. Today is PT, then bank run. That will waste the warmest part of the day.
I’ve been up since 5:30. Couldn’t get back to sleep.
I need seat time, my pellet box on porch is down to 1 bag that will go in stove tonight, need to fill the box.
   / Good morning!!!! #102,411
Hey let’s hear it for Ryobi! I have a BUNCH if 18 volt Ryobi tools, and some are quite power hungry (like the circular saw, the reciprocating saw, and my latest addition - the 22” hedge trimmer). So, I was very pleased when Ryobi came out with the big, honkin, 9 AH battery. A little hard to find, but I just picked one up from HD yesterday.
   / Good morning!!!! #102,412
Good Morning!!!! 63F @ 5:30AM. Sunny. High 64F. Winds light and variable.
The high winds expected in this area never materialized yesterday, so our electricity remained on. Of course there were no email, telephone, or text messages to that effect, I had to keep going back to the notification website established by the utility to find out. So plans to do jobs that required no power were put on hold, at least until today. The ten-day forecast is now calling for showers starting next Tuesday afternoon, with as much as an inch of rain accumulating through the following Saturday. Not enough to end the near drought we're now in, and not enough to end the fire season, either, but it's a start. The wet weather will also bring daytime highs down into the 50s, so it's time to move a pallet of firewood into the garage and get ready to fire up the wood stove. That's gonna take some rearranging, and reorganizing, maybe moving a makeshift 4'x8' work table into the warmth of the great room to keep the work on the Vanagon interior going.
I did manage to get a truck load of gravel and decomposed granite on it's way here, due for delivery Monday. Prices are up about 30% from seven years ago, but then again so is the price of #2 Diesel.
David, is it safe to assume that all those impressive sounding model numbers you rattled off are from Outback?
The current measurements from the other day were pretty inconsistent, enough so that I went shopping for a new clamp on meter yesterday. Lots of inexpensive choices out there that seem to offer heaps of features, but none of them have very good ratings. All the usual horror stories about them coming out of their boxes broken, or working for two weeks and then failing, or being very inaccurate compared to a Fluke or other reputable maker's product. My Fluke 77 meter is maybe 20 years old, and it's never asked for anything other than a fresh battery a time or to. So I bit the bullet and ordered a Fluke, one that will also read temperature and capacitance. But the real kicker is that it can be controlled by a smart phone to do data logging, and it can be monitored remotely, perfect for catching a current surge from a starting motor when the switch controlling that motor is located too far from the measurement point to reach. I also ordered a device that can be plugged into an electrical outlet that separates the two conductors safely so that the tongs on the clamp on meter can be conveniently applied. Never noticed such devices existed before, but it sure makes sense.
Rounded out the day by finishing the sound deadening on the engine deck, and getting a pretty good start on the cargo area floor of the van. I should get that finished today, then I'll tackle the broken glue joints on four of the body stiffeners in that area to quiet some rattles. I think the reed switch I ordered came yesterday (I didn't get a chance to open the package yet), and if so I'll re-rig the spoof for the neutral position switch to work off the shift linkage for a more accurate simulation.
Hang in there, gang, Friday's comin'!
   / Good morning!!!! #102,413
48°F and rain this morning, going up to 63° today. We could certainly use the rain. Looks like a possibility for snow on Saturday.
Stayed up way too late last night. Puttered around in the studio for awhile, then by the time I took a shower and got to bed it was 11:30. Boss asked me to come into work early today to help approve a rush job, and that 4:45 alarm this morning was rude.
Ron, my Wife tells me that 90% of the training she does is actually training the humans to communicate with their dogs. So, you're probably right. :laughing:
   / Good morning!!!! #102,414
ronjhall
Mother nature pruner will keep bushes trim with no problem. ;)
   / Good morning!!!! #102,415
Good morning all
Sorry I have been AWOL and have lots to catch up on hope all are healthy and doing well.
It been a busy time where it seems like not enough hours in the day, started with getting boats out of water and hasn't ended yet. I managed to get mower off the John Deere and mounting the rear snowblower and found that some time over the summer some critter chewed up the wires to the shoot control. With any luck today I'll get the bucket off and mount the snow plow this afternoon. Presently I'm cooking a stuffed pork roast to bring to my daughter at work for the office party at lunch time.
My youngest daughter rents my mom's house from my brothers and I and over the course of one week the washer 36 years old, dryer 32 years old and fridge about 60 year old GE all needed replacement so what does a dad do for daughter just starting out on her own buy new of course Merry Christmas. Guess it's true they just don't make things like they use to.
Finally did decide on a new truck GMC 1500.
   / Good morning!!!! #102,416
29F clear sky low 40's for high.
Out for my walk about before day light,found half bury turkey by good size bobcat.
2" snow fall last evening not enough to plow more than enough for Armstrong snow pusher.
Plans for today...Remove snow steps walks part of driveway,clean ashes from wood furnace,town for critter food,return to my setting place watch for wildlife...hopes bobcat will return.
Enjoy the day all.
   / Good morning!!!! #102,417
21F this morning, up a couple pounds this week, need to watch late snacking better. I was doing great without snacks in the evening, but then this week started them again. It is purely habit, nothing more. I eat a normal dinner, should not need a snack.
Stay safe, prayers for all in need
   / Good morning!!!! #102,418
There was a dusting of small intact snow on the ground this AM. *A clear and sunny*29ºF was today's low temp at ~7:00AM; a clear and sunny 39ºF presently at ~10:00AM, *10ºF in 3 hours; and I anticipate a mostly sunny afternoon high temp in the low-mid40ºF's. *It's too bad that it's going to cloud up for tonight's anticipated meteor storm with best viewing time 11:00PM - Midnight. *If I remember correctly the dominant direction will be from the S-SE. It will be a great day to putter about outdoors.
David- Congratulations on the new truck and the success of your power projects. My BIL really likes his. Do you have a cap ordered?
Bill- Good luck with the heater element replacement. Before we converted to propane heat and copper plumbing I did the plumbing work here. I can remember replacing the tank and tank elements. A wet, PITA experience.
“Mostly, you have to remember Billy is a bow hunter and they take every opportunity to build up those biceps. Bet he fills it with stale fuel on purpose and doesn't even flick the switch to "On" for the first 100 pulls ”- Eric Nothing wrong with a well primed engine :rolleyes:
RonJH- Thanks for the deer pic. They really messed with one of my resident crab apple trees. It looks like they climbed up into the branches breaking many. I am sorry to read about Sassy. I had a Doberman who once it got too “cold” :rolleye: would do her business on the slate tiles at our entrance slider while looking outside. Good luck with Sassy. Is she ok about going outdoors when it is warmer?
RNG- It’s good to see that CA is starting to get some moisture. Have fun moving wood.
Paul- I am still pondering why I always stayed up far too late the evening before a known and necessary early morning rising. I still have that tendency.
“… Mother nature pruner will keep bushes trim with no problem.”- Thomas You should see my crab apple tree :( That’s a pretty decent gift from Mother Nature. I hope you can get a picture of it. I have not seen nor heard a bobcat around here for years.
DABSGT- Nice truck.:cool:
“… up a couple pounds this week, need to watch late snacking better. I was doing great without snacks in the evening, but then this week started them again. It is purely habit, nothing more. I eat a normal dinner, should not need a snack.”- Hawkeye. I’ve been trying to eat an apple, make tea or broth instead of eating “quick eats”, wifey’s cobblers with whipped cream, or the cognac, or the tequila after dinner treat. Right now I am not gaining, but I am not losing weight either.:embarrassed:
I hope that everyone is having a decent day.
My + thoughts and prayers.
   / Good morning!!!! #102,419
69°F and .27 inches rain
Busy day ahead. Get the electrical install finished. My little Honda generator has been chugging along about 46 hours now.
Scheduled to trade trucks this afternoon.
I’ll be needing a mental health day.
Prayers for all
Be safe
Have a great day
   / Good morning!!!! #102,420
Good morning to all! Low was today's high...42 degrees. Getting colder throughout the day, rain this morning, changing to snow this afternoon. Maybe 1-3" here.
David and DABSGT, nice trucks!
Drew, I just love the look of the wreath on the barn! Reminds me of the giant wreaths on those big barns back east. Please post a pic when you get the bow and lights on it!
Still experiencing computer issues, really, really frustrating. I still have about 30 hours of continuing education credits to do online for my licensure, not fun to do when there are issues. Today's weather will keep me as a captive audience to the computer, hopefully I'll knock some of those out of the way.
Wifey has a nail appointment down in the 'big city' this afternoon. Anthing else on the agenda is an unknown.
I need to get a move on....
Everyone have a great day ! Prayers sent out.
2022 Wacker Neuson PDT2A 2in Portable Diaphragm Pump (A55851)
2022 Wacker Neuson...
UNUSED RAYTREE RMBD72-72" HYD DRUM MULCHER (A60432)
UNUSED RAYTREE...
2019 CHEVROLET SILVERADO LD CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2020 CATERPILLAR 303.5E2 CR EXCAVATOR (A60429)
2020 CATERPILLAR...
2019 Ram 1500 Crew Cab Pickup Truck (A59230)
2019 Ram 1500 Crew...
TOPCAT HCRC 72" HYD BRUSH CUTTER (A52706)
TOPCAT HCRC 72"...
