sodamo
Super Star Member
- Joined
- May 20, 2004
- Messages
- 18,478
- Location
- Big Island, HI
- Tractor
- Bobcat CT4545 LS XR4140H (Mine) BX2380 (wife’s)
Nice looking cat. We used to have 2 like that. Here's my 2 bums.32 with a forecast high of 34F. Wind NW 18 gusting to 26 mph. Mainly sunny.
The kitchen window opens up at the corner of the deck and there is a platform for the cats to rest on before they come into the house. It is that platform that I feed the stray cat on.
Yesterday morning about 4:30 A.M. the stray cat (we named him Benny, as in Benny the Bum) walked right up to me and smelled my fingers. That is progress. I do not think he is feral. I think he has a home and just wants the extra food we are putting out for him. Maybe he is being mistreated at home. We will never know and he isn't saying. He certainly looks healthy enough.
Today is another energy conversation day.
Have a good day all
Do you have water flow in the loops? Is it pressurized loops? I use the non pressurized pumps, can open and see the water flowing. Also, amp probe the wires to the pump and check current.47 and rain going to 53. Snow almost gone except in shaded areas.
BEF, thanks for help...checked, it is not set on Aux HT mode.
Eris, thanks for info and link. I will definitely go shopping for one.
Yes, a star would make it much easier to find on google maps, like i found don. LolThat's a really sharp photo at those distances. How high is it mounted? (Looks like you have room for a compass star in that patio)
Don owes you. Lol9'
I need Don's help for a compass.
Drew don’t know what they are called, but I’ve seen concrete “brick” about 1 inch or so thick but larger than brick
I suspect your 1x4 wood would soon rot
Do you have water flow in the loops? Is it pressurized loops? I use the non pressurized pumps, can open and see the water flowing. Also, amp probe the wires to the pump and check current.View attachment 583099View attachment 583100
Just to add to the drool factor, wifey took all the bones from the roasts, boiled them up, and made a BIG pot of beef soup....MMM, MMM, Good! I'm definitely spoiled![]()
David- I believe those blocks are called "pavers" or paver block.
BEF- Nice picture of the couch potato "Bums" hanging out on their sofa. Thanks for sharing.
A mixed clouds and sun 51コF outside. Aheatwave
A recently found weather site: Forecast Map Wall I can not believe it took me this long to find it. A great resource.![]()
BEF; nice looking cats.
I suspect you have a pressurized loop system, is one marked in and the other out? Or are both pumps in series with only one set of loop pipes? If it's waterfurnace, it's pressurized.
See that screw cover on the pump, with the system turned off, you can unscrew that cover, and there should be small screw slot in the end of the motor, you take a screwdriver and see if the pump turns freely. Water will leak out when you remove the outer cover, so i hesitate to tell you..
What brand of geo heat pump? Can you remove an access cover and see control boards? Look for any flashing leds.
Mine has chart inside that gives meaning of flashing code.
View attachment 583120View attachment 583121View attachment 583122
Mine uses same control board as some climatemasters. Should be same codes as in 3rd pic i posted.It is a ClimateMaster Tranquility 27. It's under the house, so I'll check your other questions tomorrow. I removed the cover and checked the LED about a year ago for a tech doing some diagnostics over the phone. I think I remember which one, but not sure how to read the flash. Thanks again.
