rswyan
Super Star Member
- Joined
- May 12, 2004
- Messages
- 13,246
- Location
- Northeast Ohio
- Tractor
- Kubota B2910, Cub Cadet Pro Z 154S, Simplicity 18 CFC, Cub Cadet 782
Currently 63F and supposedly "Mostly Cloudy" @ 10:00 ... but there sure is a lot of sun of streaming in thru the window. Had some rain last night just before I fell asleep ... local weather station within a mile of the house says we got just over 1/2" ...
Outlook for the next four days is more rain and more clouds.
Got the four tabs for the lower hitch pins welded on the 3PH frame for the LPGS yesterday. Did a little more grapple/box blade work before I quit for the day.
Also got the carb pulled of the Simplicity and cleaned out. Not hard to imagine why it had a fuel starvation problem:
I didn't bother rebuilding it ... just cleaned it out real good, put it back together, and stuck it back on. Had it purring like a kitten.
Went and got about 1/2 the lawn around the house mowed before it started acting up again, so I pulled it again ... same deal: more crud in the float bowl.
At this point I'm guessing it's fuel line deterioration (original line, circa '85 - '87) after the filter ... since it has a fuel filter on it which is clear and I can see into it and it looks good.
Cleaned it again in the hope that I could get the lawn around the house done before the rains came last night. Same deal: got a little more done and it started acting up.
So ... after doing a search for the correct size fuel line here in a little bit and probably not finding it, I'll probably be heading down to the local NAPA to pick up some neoprene line.
Once I get it running, hope I can trailer it in to cut the grass at the commercial property ... before the city gets to it.
Have to swing by Kromehard Twist Drill and pick up another snagging wheel while I'm in there, as the one I bought a couple of years ago is about gone.
