Good morning!!!!
   / Good morning!!!! #137,481
Good afternoon all! Low was 59 this morning, nice! Now it is up to 91.... a few clouds, but probably no storms will form.
We got an early start this morning doing some errands and an appointment. Got back home and had a good lunch. I still have some more errands later this afternoon. Hopefully we got them all consolidated into today.
At least I was able to pick up the materials for another set of outside steps. I'll start laying them out tomorrow. There was a good supply / selection of pressure treated in stock, and prices were way down, closer to normal (still about 20% higher).
Mostly, the knee is about the same for the last 3 months. I can only walk with the assistance of a cane if the distance is greater than about 30 feet. Anything further than that and the knee will "give out", causing a stumble. I have learned to anticipate that happening and usually results in a weird 'dance' for a step or two.... It still swells to about twice normal size after about 4 hours...
Pain and movement gets progressively worse throughout the day. I have an appointment with the orthopedic surgeon next week.
Needless to say, I am not a happy camper.....
RNG, please close the door outside..... we don't need any of the heat, smoke, or anything else that wants to drift this way! I really hope it gets better for you out there. I heard a news report saying a few of those fires won't be extinguished until maybe December.....
Gotta get at it again.... everyone have a great evening!
   / Good morning!!!! #137,482
Have you considered using a hole saw to make the cuts?
I’ve had pretty good luck doing them that way.
Harbor freight might even have a cheap jig to do them in the drill press with a hole saw. I know that there are some expensive fixtures out there.
That was my first choice, Paul. But I didn't have a 3 1/2" metal cutting hole saw, and they're pretty expensive. I was going to order one of those cutting patterns that wrap around the pipe, but Amazon couldn't get it here in a day. Then I saw that video that cutting at a 33° angle would do the same thing, and now I'm done except for cleaning up a little bit of the point with a grinder.:giggle:
   / Good morning!!!! #137,483
Believe me when I tell you, Ted, that if I could close the door to all that smoke, I'd have done it weeks ago. And if I had an A/C big enough, I'd have that thermostat turned down to a nice cool 77F. But if a frog had wheels, he wouldn't bump his butt, either. So we'll just have to tough it out and hope that the rains start at the end of September or early October, like they should. But they've been very late the last few years, so keep those thoughts and wishes comin', folks.
   / Good morning!!!! #137,484
My next door neighbor has a very tall, very dead tree that would wreck their home if it fell, and maybe if I were better with trigonometry I could calculate whether the top
would hit my home, but I think by eyeballing it the answer is yes.
Here's the egghead answer, Drew.
And of course, there's a video of an even easier way.
   / Good morning!!!! #137,485
Since we're doing math, here's a puzzler.
I put a pressure gauge on the water line coming down from the upper tank to see how much water pressure the drop down the hill would generate. I've had two gauges in there so far, and they both only read 10 PSI. Here's the math I did, and the answer was much more than what I'm seeing:
Elevation at tank site = 1229'
Elevation at hydrant site = 1176'
Height difference = 53 + 14’ at top of tank = 67’
Water pressure at pump house = 67' x .47 PSI/foot = 31.5 PSI
Any idea what I'm doing wrong? :unsure:
   / Good morning!!!! #137,486
David, good to hear you doing well.
   / Good morning!!!! #137,488
Glad you are doing well MFW sounds like the making of a home to me
Prayers for you and your family
   / Good morning!!!! #137,489
RNG again your ability and knowledge astounds me. I can search for things and never find them. Thanks for sharing
   / Good morning!!!! #137,490
Your math is fine as far as the numbers go.
1 PSI is equal to 27.707 inches of 60F water,
so, 67 x 12 = 804 inches / 27.707 = 29.0179 psi.
As far as calculating I would expect your water is warmer then 60F so the density would be a tiny bit less.
Also almost all gauges are notoriously inaccurate in the bottom 10% and the top 10% of there span,
If that is a static non flowing measurement there would be no friction losses.
If the elevation is derived from your phone or gps they are often inaccurate.
I recall a few years ago my wife and I went to Florida over Christmas and as I'm driving down the main highway my gps is indicating -60 feet of elevation.
If that pressure is while water is flowing past the gauge the venturi effect and line friction would play a large part in your numbers.
   / Good morning!!!! #137,491
Henri's rain pretty much missed us...relatively light showers on and off most of the day, but no torrential downpours.
Heading to a body shop...maybe 2, to get an estimate (or 2) on the Tacoma next Monday. I had work at one of them a few years ago when a limb fell on the truck. They did a pretty nice job then...also, they provide a rental vehicle...at a price, of course.
So, two estimates, maybe...give the insurance company something to chew on...
   / Good morning!!!! #137,492
Thanks for confirming the math, Lou.
The measurements are with static water, with the down slope valve past the gauge closed.
Both of the gauges I've tried are 0-60 PSI, so ~30 should be right in the sweet spot.
Yes, I did take the elevation measurements with a GPS, but minute of eyeball from the bottom of the hill makes that 67 foot measure seem reasonable. Can't see the tank from the bottom of the hill, so I can't use the technique in that video I flagged for Drew, but I don't think the elevation is off by more than ten feet.
When I unscrewed the first gauge, I slipped my thumb over the 1/4" pipe thread opening and was able to stop the flow of water. Not sure I'd be able to do that at 30 PSI.
The route the plastic pipe takes down the hill has lots of ups and downs (I'm kinda a crappy backhoe operator), so there's a pretty good chance there's still air in the line. I know air is compressible, but it seems to me it should still "transmit" pressure above an air pocket to the incompressible liquid below. Maybe I should break out my old college physics book and brush up on my pressure mojo?
   / Good morning!!!! #137,493
And I can put something down on the workbench right in front of me and spend an hour looking for it.
Guess it kinda evens out, huh? :ROFLMAO: :rolleyes:;):oops:
   / Good morning!!!! #137,494
Overwhelmingly in most cultures the mantis is a symbol of stillness.
As such, she is an ambassador from the animal kingdom giving testimony to the benefits of meditation,
and calming our minds. An appearance from the mantis is a message to be still, go within, meditate, get quite and reach a place of calm.
strange take on an apex predator; tons of youtube videos on how ferocious these bugs are
of course it does sit there like a quiet stick, blending in, waiting for its next meal.
maybe it is meditating, who knows...
interesting I was told early on by parents to leave that bug alone, not to hurt it, that it was a good bug like a lady bug.
We called the males walking sticks.
   / Good morning!!!! #137,495
Been there done that too many times
   / Good morning!!!! #137,496
Back home from my 2000 mile journey to get my youngest back to college, 700 miles today. This is his last semester, graduates in December in Business Information Systems with minor in Network Security.
We stayed with old friends, had a good visit. Also stayed with our other son both directions, so no hotels this trip. The easiest move I’ve done.
And successfully went across the newly reopened I40 Memphis bridge twice.
   / Good morning!!!! #137,497
Good evening all. 72F for the start, mostly clear sky, near calm wind. Light wind today, sky stayed mostly clear, and high temp was 94F HI 103F and DP 72F. Mow the front that needed bagging, bike ride and the mowed back and side yard. Then napped, hard work sweating that much :)
Covid update: Cooke 3546 confirmed cases, 78 active cases, Montague 2002 confirmed cases, 61 active cases, Grayson, 12715 confirmed cases, 245 active cases. Cooke 0, Montague 0, Grayson 0, new cases.
RS but the ground hog or moles/gophers do it anyway. Glad you enjoyed your nap
Roy hope the weeks delay does not hurt you or the truck. Good luck on the requal.
Ron looks like the ground hog will do it for you :)
Buppies hoping heat does not last till mid September :(
Drew sorry about the problems at church.If a guy with a gun shows up what to they want to do? He is there to shoot and kill people.
Rich have fun with unstructured day
Paul glad rain did not disrupt the grinding. Be safe on your trips
Don good luck with blood test and planning and cards
RNG sorry about the effect of the smoke. good to hear screener is progressing.
Ken have fun processing the wood glad family and friends ok after storm
Drew good luck dealing with tree.
RS oh dear, no coffee :( Have fun with your opportunities
PJ glad your fried made it home. I find walking the string trimmer helps the look of the place but the trimmer never says thank-you or anything :(
David sorry about spill, looking better all the time
Drew nice pic hope bushes survive.
David tell Sophie nice pic :)
Thomas nice nap
PJ sorry about the traffic
David good to hear from you. Great news on progress. Doing well here.
Doug are the new lock-downs going to mess with remodel plans?
Ted thanks for knee update, praying it will get better.
Dennis glad move went smoothly, did not know bridge was reopened again.
prayer for all, especially Jay/Peg, Kyle's daughter, Bird/aging issues/, Randy/FIL living alone adjustments, PJ/FIL fall and stroke, David(moss)/remodel/divorce, Buppies/new areas, Thomas/gout, Phil/reflux/wife's eyes,Steppenwolfe/son-auto immune disorder/Dad's passing, Grev/wife's eye, Bill/DIL home care, Ted/knee recovery, Doug and wife/health issues/nerve and pain/ wife's eyes, Ken/uncle, Drew/tendon healing, David(sadamo)/Sophie's eye surgery/Back issues, RNG/fire season, and Country.
stay safe and healthy you all.
   / Good morning!!!! #137,498
Didn't do much during the day Sunday. Too hot and humid.
After church, sprayed a bit of round up trying to kill some nutsedge in my little front bed with 3 tiny rose bushes....2 rose bushes went to rose bush heaven after accidentally getting weed whacked, due to high grass growing amongst them.... then went to walmart for a handful of items.
At 7:30 when the sun was almost down, we went to the city's old tennis courts and batted the balls around a bit. I took it easy, still having shoulder/elbow problems from wreck back in May. It was hot. Maybe a good thing the court's lights wouldn't come on. cut us short on time.
My good friend at work is still on ventilator.
My other friend found a super clean Kuhn GM 280 hay cutter from a guy he knows, not too far away. He's already bought it. He got heat exhaustion today.
I took the Gator HPX carburetor apart for the 3rd or 4th time (in the last month)....I turned on the key to see if fuel comes flowing into the venturi ports..nothing noticeable. Then I held a clear tube connected to the bowl's drain adjacent and the fuel level looked OK, maybe 5-8 mm from the top of the bowl. I then took the bowl off and brought the carb inside to look at the brass seat (that the needle fits into). Either it is worn out, or it was made poorly. Not a good chamfer, nor a good finish. It almost looked "grainy". Maybe that's wear and tear. Anyway, I could see how that could leak. I'm going to take it to work and attempt to polish it with maybe a small 3-4mm wooden dowel. If I cant get it righteous, I'll put some threads in it and pull it out to make a new one.
   / Good morning!!!! #137,500
Friend's new to him Toy hauler. weighs 18,000lbs. We used a 5th wheel he had purchased, but the previous owner threw in a hitch with air bags. I'm hoping the airbags help, that thing shook the truck fore and aft so much, it was uncomfortable. Is that normal?
2015 International TranStar 8600 T/A Day Cab Truck Tractor (A59230)
2015 International...
2016 KOMATSU D65PX-18 BULL DOZER (A58214)
2016 KOMATSU...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
2019 Deere 35G (A53317)
2019 Deere 35G...
Year: 2016 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55853)
Year: 2016 Make...
2005 BOBCAT T300 SKID STEER (A60429)
2005 BOBCAT T300...
