Good morning!!!!
/ Good morning!!!! #137,501
0, new cases.
We only has 24 new covid cases today. Last week we saw wavering totals 200-300 and up to 500 one day the week before. We might have reached the peak last week and we are coming down just as predicted. We should know by Wednesday.
My un-vaxed friend is not doing any better after 2 weeks and antibody infusion. The Ivermectin (ag. grade) did not work at prevention or to lessen the symptoms.
RNG is there anyway you can test the gauges for accuracy?
/ Good morning!!!! #137,502
TwoBit, thanks for explanation.
I grew up outside a town that was at one time 50% gay, and for many that made it
pretty "weird". Thankfully it was also a great opportunity for learning tolerance, which most of us did.
Texas really does have different areas, different people, quite a melting pot.
Different is good, but we can all be good citizens in our own way.
I think most would like to think your statement is true: “Different is good, but we can all be good citizens in our own way.” I remember Austin when it was true. But now the definition of “good” and “good citizens” has been changed by some to the point that getting back to that will be very difficult.
/ Good morning!!!! #137,503
My first try was with a junk drawer gauge that I plumbed up with an air fitting. It registered in agreement with the gauge on the compressor, and with a fancy race car tire gauge. And, as it turns out, with the two gauges that are made to work with water. So I don't think it's a measurement error at this point...
/ Good morning!!!! #137,504
mostly Gas, We are not in lockdown, just NSW and Vic. However, if the infection gets into Qld the situation could change. Cross fingers.
/ Good morning!!!! #137,505
2021-08-24, 0323
68° right now...high in the mid-80's today...
Audit is going OK so far. One issue, which I'm not going into since it would take way too long to explain (and make sense), arose. It's not particularly applicable to the site I work at, but it is a problem we'll need to help fix (as it affects more than one site). The joys of Quality Management!!
Pallet forks should be delivered today...hope they show up...
/ Good morning!!!! #137,506
Need to pour first cup of coffee. 62° with clear skies this morning. Heading to 89° with lots of sun. Got shop cleaned up and grass mowed. Have a couple LED flood lights to mount and wire in barn today. Then back into house where it is cool.
Fawns have lost most of their spots.
Roy, hope pallet forks show up as promised.
RNG, I call that tunnel vision. Happens to me all the time.
Rich, you on vacation this week?
Kyle, that's a very large toy hauler. They are a tuff tow.
Buckeye, glad trip taking son to college went well.
MFW, good to hear from you.
DAvid, great Shoph picture.
Everyone stay healthy and safe.
Good Morning All.
/ Good morning!!!! #137,507
good morning all.
Bright sunshine today, what a switch from the last few days when 3.25 inches of rain came down.
busy day, off to have coffee and coffee cake with my 94yo MIL in retirement place in Doylestown, then off to lunch with friends
from church at another local retirement place, Pine Run, where I will be given the church security project.
and then home to mow the lawn which is growing rapidly from all the rain.
Kyle, modern diesel dually should pull that without a problem, likely issue is in hitch. Most good fifth wheel hitches have shock absorbers in them which
absorbs a lot of the forward and aft motion. Without them I've read it can be pretty jerky.
90 and sunny today, with all this moisture around likely a little sticky too
/ Good morning!!!! #137,508
70 high of 93 today no rain for rest of week
No new bear sightings
{racers for all
/ Good morning!!!! #137,509
Good morning all. Had a trip to timber yard yesterday and ordered some oak glazing beads for the windows, together with a few sheets of birch ply. That stuff is now so expensive, wouldn't be surprised if delivery truck has armed security guards.
I know air is compressible, but it seems to me it should still "transmit" pressure above an air pocket to the incompressible liquid below
RNG, I think that is true for a small air space, however assuming your gauges are reasonably accurate and there are no leaks in your pipework, then possibly it suggests there is quite a significant amount of air in the pipe, causing the computations for the vertical component of the "weight" of water in the pipework to be way out.
Can you try fully opening the end of the pipe and let it rip for a short while, or alternatively pump water up quickly through the bottom of the pipe until the tank stops bubbling ?
Rowan trees must be one of the most consistent at providing fruit for the birds. They seem especially bountiful this year.
/ Good morning!!!! #137,510
Good Morning
70 with a high over 90 forecast with brilliant sun all day.
Yesterday had bands of heavy showers passing bu throughout the day bringing the total rain to 3”. So it’s pretty squishy out there.
Got some progress made in the shop before I had to head out to the airport. It was interesting getting around the thunderstorms, had to go a bit out of the way, but not a a bad trip overall.
Today, I’m getting ready to head out to Huntington, WV to with there all day and get home after dinner. But that should conclude my work week, hopefully it will dry up enough to mow tomorrow. I’ve got no idea how I ever found the time to work every day!
/ Good morning!!!! #137,511
Kyle_in_Tex said, "I'm hoping the airbags help, that thing shook the truck fore and aft so much, it was uncomfortable. Is that normal?"
I can assure you that it is NOT normal. Without seeing it closely, I can't say what the problem is, but it could be a number of things; hitch mounted in the bed of the truck too far back is the first thing that comes to mind, but may not be the cause. He needs to have an experience hitch installer check it.
/ Good morning!!!! #137,512
72 and ground fog. Going to 93.
RNG, very interesting water pressure dilemma...glad you are getting good input.
Sounds like a dead wind day, so once the dew dries, will mix up 50 gallons and spray.
Got a roofer coming this afternoon for an estimate. We went to their "showroom" yesterday. They also do decks...use a brand called Wolf made of PVC rather than composite, like Trex, etc. but will do some research since I want to build that project myself. The roof shingle color we want is temporarily not available due to the C virus impact. GAF is only making 3 colors...wife is okay with one so we may green light the project after a couple more estimates. Next estimate will be a roofer that uses a different company's shingles so they may have our color.
/ Good morning!!!! #137,513
Thanks for the tips y'all. I will say that on smooth paved roads, it rode OK. But add some bumps, it made it shake. Hopefully the airbag hitch will work much better.
/ Good morning!!!! #137,514
Have you considered a metal roof? They last a lot longer, are more hail proof, and can get you a good discount on home insurance.
/ Good morning!!!! #137,515
Good Morning!!!! 64F @ 5:00 AM. Abundant sunshine. Visibility reduced by smoke. High 88F. Winds S at 5 to 10 mph.
That's quite a rig, Kyle, even to the color coordination. We took the neighbor's goose neck trailer to the scrap yard yesterday, and I couldn't even tell it was there on the trip down and back. The first and last five or so miles are pretty bumpy country roads, too, but we only had 500 pounds of steel for payload.
That one and only water truck delivery was pumped to the high tank via the drain line, Eric, so that should have purged it. I've also fed the low tank a couple hundred gallons from the high tank, again through the drain line. But what I can do, since the trench is still open, is lift the drain line and sort of walk it up the hill starting at the bottom, and that will maybe force any bubbles up the hill and burp them into the high tank. I also haven't tried to draft water from the high tank with the fire truck yet. That's the whole reason for the high tank, and as soon as I get the trench filled in I'll move the truck within suction hose range and we'll see.
Those Rowan berries look an awful lot like what we get on hawthron trees here, Eric. Wonder if they're in the same family. Do Rowan trees have thorns like hawthorns?
I haven't seen it mentioned in the Austin dialog yet, but my guess is it has the same kind of problems with homelessness as most towns in California. Chico, CA is one of them, too, but in the last election, five of the seven city council seats were won by folks that feel offering a hand up, rather than a hand out, is a more appropriate response to the problem. First thing they did was ban a state run hypodermic needle hand out program, and the next thing was was ban camping in public parks. The parks have been destroyed, physically, by transients: filth and needles everywhere, feces and trash in the waterways and creeks, crimes including murder in the parks. But a lawfirm filed a suit against the council and got a stay in enforcing the ban until the city can come up with an alternate housing plan for the homeless. Apparently in another case in another state supreme court it was ruled that you can't arrest people that can't afford campground fees and who insist in camping on public property. So now even small towns across the country are being forced into housing people at taxpayer expense. That kind of legal maneuver does nothing to help the homeless, it only prolongs and enables their squalor, drug abuse, criminality, and poor decisions.
We made out pretty well at the junk yard yesterday. We were all set to snag a pile of brand new rectangular and square tubing, but the forklift driver said it belonged to the owner who had just purchased it for one of his projects. :oops: :ROFLMAO: Still lots of choice for alternates, and I think we're good for the grizzly frame now. We even found a 1" grid mesh made from really heavy wire that will work fine for screening out soil. I was able to get the front part of the grizzly tacked together and up on some sawhorses to finish welding. Had to stop when the wind kicked up and blew the shield away, though. So that's on the agenda for first thing today.
/ Good morning!!!! #137,516
Good morning! 68 now, supposed to be 89 later. Yesterday was steamy working outside, guessing today will be worse…..
Have rented a storage unit for years….kept saying it needed to go. Yesterday was the day. Stuff I wanted came home, including some items that are for sale, some stuff went to the dump, and found someone near the storage unit to haul some stuff away. Then came home and found a place to put stuff. Just glad it is done
Yes Ron, I am on vacation this week. We have to use our vacation time before our anniversary date. I had 102 hours left at beginning of August, got it used up.
Not sure what type of trouble I will find today
Everyone stay safe out there
/ Good morning!!!! #137,517
Morning all, sun is out and it seems rain is finally moving out.
Got kids rear bike tube changed out and some other small stuff done. Starting to feel a bit better.
Maybe time for a new larger chain saw?
Still need to change oil on tractor and do a generator check. Wife had to go into work today and alarm people here later to check faulty sensor.
RNG - I measure the trees when they hit the ground, average for the Ash we are taking down is about 90' tall. So Drew's could easily be in that range. Like the indirect measure video, quite useful.
For the water pressure, is their any increase in pipe diameter at gauges?
Air could be the culprit, but using a larger diameter at the top to a smaller one will increase pressure if you need a free boost at the tank.
Stay safe and be well
/ Good morning!!!! #137,518
RNG - For the water pressure, is their any increase in pipe diameter at gauges?
That's interesting, Ken. The drain line coming down from the upper tank is 2" HDPE, and it necks down to 1 1/4" PVC for the last ten feet at the gauge location.
Perhaps a sign that there is still a lot of air in the line is that I can feel the pressure under my thumb rise and fall in a kind of wave when I pull the gauge off and cover the hole with my thumb. I don't think it would do that if the air was purged out of the line.
/ Good morning!!!! #137,519
Yes you can get a discount for a metal roof from most insurance companies. Usually they will also add an exclusion for cosmetic damage from hail. So, that means if the metal roof is damaged by hail, no matter how bad it might look, if there is no water intrusion they won’t have to pay anything.
Watch out for those exclusions. Also, be sure you know if the policy will pay Actual Cash Value only or if Replacement Cost is included in the price.
And there is no such thing in the insurance business as ‘full coverage’, legally.
/ Good morning!!!! #137,520
86, feels like 95 at 10 am. High of 90 predicted.
I discovered that somehow last week I lost three prescriptions I’d picked up. If I have to pay out of pocket it will be around $700.
No idea where when or how.
RNG, what certain municipalities and courts with a certain mindset don’t seem to grasp, is that you can’t break bad habits by enabling them.
Love the new building ramps, the concrete is just better in every way.
We took the El Camino to the resto shop yesterday. Should be done late fall or early winter. Hopefully it’ll be show worthy and cruise ready when it comes back.
2016 John Deere 4044R 42HP 4WD Utility Tractor (A59228)
2016 John Deere...
Honda EM3800SX Portable Gasoline Generator (A59228)
Honda EM3800SX...
2022 JOHN DEERE 700L LGP CRAWLER DOZER (A60429)
2022 JOHN DEERE...
DRAGON 500 BBL FRAC TANK (A58214)
DRAGON 500 BBL...
Year: 2016 Make: Ford Model: Taurus Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 Door (A55853)
Year: 2016 Make...
2014 Tesla Model S 60 Hatchback (A59231)
2014 Tesla Model S...
