lostcreekranch
Super Member
- Joined
- Dec 14, 2012
- Messages
- 8,078
- Location
- Austin County, Texas
- Tractor
- NH TL-100A with Bush Hog 5045 FEL, WR Long 3rd function, LS XR4155HC w/FEL, WR Long 3rd Function.
Position of cylinder rod will change after setting to proper length. Check valve should lock it in place. I only use top and tilt cylinders with rear blade and landscape rake. Want to use top link with more attachments.
I asked because I have a similar issue with my LS XR4155HC. Both top and side link cylinders extend fairly quickly under load. I can disconnect hydraulic hoses from the QD’s and nothing moves so, it’s valve block, for the three remotes, that’s the problem. Is that your issue as well??
Mine is still under warranty so, I’m pressuring the dealer to get this resolved.
Which check valve did you buy?
