Good morning!!!!
   / Good morning!!!! #104,631
Same issue as you have. Not sure you could fix it with replacing valve. I have 5 different valves on my tractor. They all leak down some. More noticeable with my small cylinders on top and tilt.
I got mine from Agristoreusa.com. 10 1/16" kit.
Rick, if you order one of the valves. Make sure it will fit you cylinders. I need to modify mine to make it work. Which I was aware of before I bought.
   / Good morning!!!! #104,632
28°
In to work a little earlier, but waste lots of time in traffic going early.
Calling for 1-3” snow later. That will shut down this area
   / Good morning!!!! #104,633
When I bought my last house it came with a tiny Jotul wood stove. Was cute. I sold it and bought a stove that would hold a 24” piece of wood.
   / Good morning!!!! #104,635
Thanks Ron. I’m going to put significant heat on LS to resolve this ... before going that route.
   / Good morning!!!! #104,636
I’m not sure I’m understanding exactly what you and Ron are talking about with the valves, maybe I’m just dense. I’d like to understand it if you don’t mind dumbing it down a bit.
   / Good morning!!!! #104,637
Just started to snow here in upper MD, but almost quit after about 5 minutes. Forecast is for 1-3”, but I’ll believe it when I see it!
   / Good morning!!!! #104,638
I left work before it started there, but was already accumulating at my house.
Was in some heavy snow on I70.
Around 1/2” on now and snowing steady. IMG_3079.JPG
   / Good morning!!!! #104,639
Check valves are an added safety feature that keep the cylinder locked in position and prevent drift.
Year: 2002 Make: Ford Model: Econoline Vehicle Type: Van Mileage: 156,145 Plate: Body Type: 3 Door (A51694)
Year: 2002 Make...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A55302)
Kubota SVL65-2...
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A55314)
2023 Kubota...
2013 Ford F-150 Ext. Cab Pickup Truck (A53422)
2013 Ford F-150...
2016 Freightliner M2 106 Braun Ambulance (A53422)
2016 Freightliner...
NEW  STARTER (A55745)
