Good morning!!!!
   / Good morning!!!! #104,631
Same issue as you have. Not sure you could fix it with replacing valve. I have 5 different valves on my tractor. They all leak down some. More noticeable with my small cylinders on top and tilt.
I got mine from Agristoreusa.com. 10 1/16" kit.
Rick, if you order one of the valves. Make sure it will fit you cylinders. I need to modify mine to make it work. Which I was aware of before I bought.
   / Good morning!!!! #104,632
28°
In to work a little earlier, but waste lots of time in traffic going early.
Calling for 1-3” snow later. That will shut down this area
   / Good morning!!!! #104,633
When I bought my last house it came with a tiny Jotul wood stove. Was cute. I sold it and bought a stove that would hold a 24” piece of wood.
   / Good morning!!!! #104,635
Thanks Ron. I’m going to put significant heat on LS to resolve this ... before going that route.
   / Good morning!!!! #104,636
I’m not sure I’m understanding exactly what you and Ron are talking about with the valves, maybe I’m just dense. I’d like to understand it if you don’t mind dumbing it down a bit.
   / Good morning!!!! #104,637
Just started to snow here in upper MD, but almost quit after about 5 minutes. Forecast is for 1-3”, but I’ll believe it when I see it!
   / Good morning!!!! #104,638
I left work before it started there, but was already accumulating at my house.
Was in some heavy snow on I70.
Around 1/2” on now and snowing steady. IMG_3079.JPG
   / Good morning!!!! #104,639
Check valves are an added safety feature that keep the cylinder locked in position and prevent drift.
10' CONTAINER (A52706)
2014 Toro Z-Master 6000 Series 60in Zero Turn Commercial Mower (A59228)
2014 Toro Z-Master...
iDrive TDS-2010H...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2014 MASSEY FERGUSON 5612 DYNA-4 TRACTOR (A59823)
2014 MASSEY...
5ft Rotary Brush Cutter Tractor Attachment (A59228)
5ft Rotary Brush...
