Good morning!!!!
/ Good morning!!!! #26,401
Drew nice pics :2cents: :thumbsup:
Dave, do you 4WD on your TC? I never ran chains on my 1700(4wd), and did not need them except for the ice/sleet storms which were few and far between here.
Mostly I run in 2WD with chains on all four. The front chains are small, widely spaced vbars for steering control mostly. After two winters here, I realized life was not going to be fun without chains. :laughing: I did a slo-mo 360 once on the tractor going down the driveway and it isn't all that steep. Got stuck several times and said phooey on this routine.
Our driveway is gravel and usually has an inch or two of packed, icy snow on it which stays all winter unless we get a decent January thaw.
/ Good morning!!!! #26,402
Drew, all the pictures of cypress reminded me of the clock on the Conference Room wall here at the Civic Center. They have laws now that restrict the harvesting of cypress knees, but back in the day, no arts and crafts show was complete without a few pieces crafted from cypress knees. The family that funded the Civic Center made their money in the timber business, so this always seemed to fit the building just right.
Larro
/ Good morning!!!! #26,403
57F @ 18:00 ... just came in to grab some coffee.
The kid done pretty good ... he wasn't here all that long (had to go pull a rear end out of a truck) but got a lot of fire wood cut up and a couple more trees taken down. Also helped me unload the concrete out of the van. I got several locust poles hauled up to the shop to stack the firewood on, cleaned up the area where the wood will be stacked, and checked the gutter on the shed (no leaves :D)
After he left the wife and I worked on more leaf pickup ... got the lawn around the house all done (again), cleaned out some planting beds, and I got about 2/3's of the front lawn run over (again)
The area around the polebarn still needs done ... will try to get most of that picked up tomorrow but there's enough wet stuff that I probably won't be able to get it all. Still, overall it's probably the best we've done in recent memory.
Replaced the belt on the Simplicity and got the oil for engine oil change on the Kubota picked up. Need to pressure wash the wood chipper and the snowblower and clean out the sprayer tomorrow.
Gonna head up to the shop now and do a quick clean up and see about pouring that ballast block.
Oops ... not quick enough ... sounds like I need to go unload groceries ...
/ Good morning!!!! #26,404
Concrete is poured on building. Take forms off tomorrow and saw it. Hope everyone had a productive day.
/ Good morning!!!! #26,405
Nice :thumbsup:
Pics if ya can ...
/ Good morning!!!!
We have a concrete shortage up here. I just read that some projects are being postponed until next year. Highway construction gets first dibs.
/ Good morning!!!! #26,408
2014-11-11, 0327
28 right now, high of 57 and clear today...
/ Good morning!!!! #26,409
geez Roy, you are late. Shake a leg....;)
Boss man gets to sleep in though...
warmer day today, in the fifties already, might hit 72. Could be the last day in that temp for awhile. Hopefully some rain later, hopefully.
Going to see if I can locate my dibble or bulb auger; if not need to run to Lowes to get one. Have about two hundred daffodils and tulips to plant.
Considering the fact that my right hand and fingers were swollen up like fat little sausages on Saturday, likely from just overwork, I might wait until my helper shows up tomorrow. since there is a possibility of some rain today, makes sense anyway; why plant in bone dry hard dirt if it can be avoided. I'm planting along the woods so actually nothing gets overly dry there anyway; so self mulched from pine needles.
My sister and I planted the last four of the shrubs I bought a month ago, so these bulbs will be my last planting of the year. Well, not quite...those ten fruit trees are going in within days. Have the rows all measured out, little pins down for the trees, just wanted to talk to the ag agent locally. And come to find out yesterday he "took another job" and no one is replacing him. Great. And they gave me the number of the Pitt Co contact, one county over. I'll call him today.
I'm going to be planting about thirty or forty trees. Have six apple and four pear already. No more pears; the fruit doesn't keep well enough for me. But lots more apples, and peaches. Of course peaches don't keep well either....hmmmm. Maybe more apples. Still need to find some crabapple trees, but not in a rush; just will leave space for them in the apple portion of the orchard. It's where to put them...on the outside or the inside? Three rows wide, thought of putting them on the inside row, but then thought about the outside. Pretty wind protected area but most exposure is from the South and West. Ok all you little pollenizers, how do you fly around?
/ Good morning!!!! #26,411
30 degrees and heading to the mid 50's today partly cloudy but dry
Good to be home and will be doing fire wood work today.
/ Good morning!!!! #26,412
2AM, temperature alarm went off in the water building... went outside to turn a heater on in there, and that wind chill had to be in the mid to low teens already. COLD. First real cold we've seen this season, so I am not going to complain to much, it has been a great year.
1 is outside
2 is electrical building
3 is water building
4 is inside
Tomorrows project now, is to install the automatic heater (in box on floor) in the water building. I had to step over it, to get to the other heater to turn it on, while freezing my hind-end off.
~Moses
/ Good morning!!!! #26,413
36 this morning but temperature will rise close to 70 today with light winds. The coldest temperatures of the year arrive Friday with projected high of 38 low 25. Another good working day I think
Good Morning
/ Good morning!!!! #26,414
Poured second cup of coffee. 43° with mostly clear skies this morning. Heading to 57° with chance of rain when cold front moves in. Going to change oil in motorhome today. Was going to get it done during our trip west. But after reading a thread on Diesel Place. Going to do it myself.
Good Morning All.
/ Good morning!!!! #26,415
28F clear sky high upper 50's,wish I could play hooky from work on days as such.
Last 20 mins 4 deer have pass by heading for the high grounds to bed etc.,which means flock of turkey's soon to arrive to start picking.
Have good day all.
/ Good morning!!!! #26,416
37 and foggy...should hit 67 today.
Heading down to Chesterfield to have lunch with a former employee today. Good to catch up on things. Then back home to paint before too late - only have today and tomorrow before the cold hits.
/ Good morning!!!! #26,417
sorry Billie but you are going to get wet before you get paint down if that nice fat swirly storm off the coast heads North.
Looks to be a little NorEaster. Bring that rain on, I sound like TxDon, its really dry here. And I have a ton of fresh sod laid that is chanting
for rain outside. We want rain. We want rain...
the last four systems have missed this entire area.
Looks to be a good one coming.
hmm, few things to put away near the barn before the rain comes.
Time for a second cup of coffee and a walk to the barn.
/ Good morning!!!! #26,418
Thanks for the warning. We need the rain, too. The local weather guy said any rain would pass east of I-95, and we have a 20% chance of rain/snow Thursday/Thursday night.
But I'll take another look at the forecast before I drag out the sprayer, ladders and equipment.
/ Good morning!!!! #26,419
39F with fog. Mid-50's again today.
Picked up some rubber tarp bungees and hydraulic fluid yesterday, hope to finish up the chains and get the hydraulic oil & filter done today. Need to go to the grocery too sometime today.
The local TSC now sells Sta-Bil diesel treatment and biocide, hadn't seen that before. The Kubota dealer sells Shell Spirax hydraulic fluid. Said they only recommend Kubota UDT during the warranty period since it is so expensive. The Spirax was $68.75 for 5 gal.
$145 for 10 gal of Spirax plus the expensive hydraulic filter makes that a pricey maintenance item.
/ Good morning!!!! #26,420
Morning all, 43F here with temp jumping up to 61F by this afternoon. To bad it is also calling for rain.
LOT LOCATIONS (A59905)
2005 Chevrolet Impala Sedan (A56859)
2005 Chevrolet...
2012 International 4300 Reefer Truck (A61306)
2012 International...
KBH Water Trailer BNT-1 (A61306)
KBH Water Trailer...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59904)
2019 FREIGHTLINER...
(2) POLY DRUMS (A52708)
(2) POLY DRUMS...
