Good morning!!!!
/ Good morning!!!! #216,961
@Popgadget sorry to see the fire and I'm sorry that you are losing your alpacas. That must be hard.
Impressive gear print! I think back on various items that were trashed because a gear deconstructed and I wasn't able to find a replacement.
I'd be counting my blessings that the tanks didn't fail during the fire. (And they have been now been dumped/vented, right?) I've seen what a compressed gas tank failure looks like. It isn't pretty, especially if one or the other ends failed.
@daugen when you posted "fan rattle", I have to admit I was thinking mice and loose nuts, as it has happened too often to my vehicles over the years. I'm glad that you and Ken got it fixed. Personally, I'm a little annoyed that manufacturers don't do a better job of screening cabin, and engine, air intakes. I had an engine air filter completely filled with acorns by some industrious mice. What amazed me was that the 7L diesel ran just fine (no pressure drop measured on the air intake gauge), but as far as I could tell, the entire housing and intake had been filled with acorns, perhaps two gallons worth. Personally, I would go on a hunt to try and find the 1/2" hole that they got the nuts through to avoid having it happen again. One of my trucks has 1/8" screening in the air intake cowling, but a 1x4" gap at one end, and yup, one year mice moved in. Half the width of the truck was body metal enclosed channel under the windshield and the mouse nest was at the back of it, just over the cabin air intake that was screened just fine enough to keep the mice out of the truck cab. After disassembling the cowlings, and wipers, vacuuming out the nest with a shop vac and some creative extensions was ok, but cleaning the mouse pee took days of cleaning, rinsing, sanitizing, and repeating. The drain for the space was pencil size, and too much spray caused it to run into the cab. Not my favorite project.
We had a surprise (not in the forecast) rain last night that started just as we were out feeding the animals. The dog loves the scents, but getting her double coat undercarriage clean is always a challenge. I'm considering one of those blow dryers for dogs.
34F outside, but no snow overnight as the snow level looks to have been several thousand feet above us.
All the best,
Peter
/ Good morning!!!! #216,962
Got shelving done.
Moved solar panel for the oldest eufy camera to get more light
Watching squirrels chase each other, jumping tree to tree.
BB giving me a bath
/ Good morning!!!! #216,963
I got another call later stating that they reviewed surveillance footage, and our locker was a victim, not the instigator.
The apparent source was an extension cord plugged into an engine heater.
Sorry about your fire. Glad they cleared your locker as not the cause.
/ Good morning!!!! #216,966
Post from yesterday that didn't get posted:
42F and foggy @ 16:30 and that should be the high for the day. Calling for a low of 31F overnight tonight.
Rain yesterday melted all the snow.
Picked up med was doled out.
Trip Menards in Tallmadge/Kent was made and all items on the list picked up.
Ran the endoscope up beside the stack/vent pipe. It does appear to go all the way to the top of the wall. Was hard to make out what happens there ... at some point in the future I'll get up in the attic over the garage and see if it penetrates into that space. But that won't happen until I get enough room out in the garage to set up the tall stepladder underneath the access door.
So I held off on picking up an air admittance device until I can figure out what's going on.
Also ran the endoscope down below the floor in the crawl space. Someone else besides myself was very interested in that space:
Lot's of cobwebs and what I would presume is bare dirt down there. Did not see any critter holes ... but then I did not do a thorough inspection just a quick look. May revisit that before I permanently close up the wall.
Apparently the 3rd time was a charm as far as the drain went:
Got holes for the drain and water supply lines drilled through the bottom stud on the shared kitchen/laundry room wall and a couple of holes for the supply lines in an adjacent stud:
Didn't drill the one for the drain until I can figure out the height that it needs to be.
Water supply valves for the stationary tub taken apart and then sweated off the stubs and stubs trimmed back.
A pair of 1/2 sweat x 1/2 male pipe fittings sweated on.
Used the new cable saw to cut off the abs lateral to the dedicated drain for the washer. First time I had used one, worked ok ... but because it uses friction the plastic tends to "weld" itself back together requiring another pass through. Can see how it would be handy for stuff in locations that are otherwise near impossible to get to. Worth the $5 price of admittance if you're dealing with those situations.
After that I used the Dremel Multitool to cut the drain line in 2 places and removed that section of pipe:
This photo not uploading for some reason.​
/ Good morning!!!! #216,967
56F and "Fair" @ 14:00 and that should be the high for the day. Calling for a high of 60F tomorrow ... far out of the norm.
Yesterday I attempted to use the cable saw to trim off the remaining vertical leg of the laundry drain line.
Getting the cable down around it and in position was a complete PITA and required using a prybar to lift the pipe due to lack of clearance so I could slide the cable underneath.
Fortunately while I had my fingers down there I discovered the big fat cable carrying 220v to the dryer ... :oops: ... and I made sure to avoid looping the cable around that ... ;)
One thing I did find with the cable saw was that once you start and it really gets cutting is that you have to keep going and not stop until the cut is complete ... otherwise the cable gets "glued" in there and stuck and won't move.
Getting it unstuck required using the prybar to push the cable further down, to where it had already cut the pipe, to free it up.
I eventually did get that vertical leg cut off and removed ... which should allow me to pull the remainder of the pipe out into the basement, completely removing it.
Then unwound the heat tape from around the water supply lines.
As ponytug suggested I did find that one of the two wires in the heat tape was broken ... had chunk missing from it. Whether that was from some critter chewing on it or just the incompetence the idjits who originally did this "renovation" who knows ... just thankful there wasn't a fire as a result.
Then did a similar "cut and remove" with one of the two water supply lines. Still have to do the 2nd one.
Today we'll start working on installing the supply and drain lines in the laundry room.
Hope everyone is having a decent day ... (y)
/ Good morning!!!! #216,968
Trip to town was kind of a bust, other than I did get Chinese for lunch. Also delivered another 5 gal of used oil to recycle. Ordered trex fascia at HD for the deck. Should come in next week.
They were out of posts for my fence, Lowe’s also had none. tractor supply only had jeans for short people.
Bought new clasps for flag lanyard, but they kind of small. Ordered some on Amazon.
Pebbles now asleep on me.
/ Good morning!!!! #216,969
68°F and 0 rain
Kekoa got his stitches removed from his lumpectomies.
Capacitor for range hood came in early, that will be my focus today. Removing 18 years of grease build up will be the fun part. A couple cans of Easy Off to help. I’m sure some disassembly required to get the squirrel cages.
Prayers for all
Be safe
Have a great tractor day
/ Good morning!!!! #216,970
32F cloudy upper 30's for high felt good.
Good day at work somewhat of busy afternoon stop for critter food,all roof clear of snow for the incoming nasty storm this weekend.
Plans for the evening after dinner feet up good chance pillow time will come early.
Enjoy your evening all.
/ Good morning!!!! #216,971
Good (Friday) morning. Overnight Low of 14C and it's presently 20.3C, overcast with a gentle breeze. There was a surprising 0.2mm in the gauge @ 0900.
The heatwave appears to be over for Tasmania especially as the temperature started to decrease shortly after my posting yesterday. Not so for South Australia and Victoria who are hitting mid-40C with high winds. A couple of 'catastrophic', out of control bushfires are happening there now with multiple structures lost.
My tractor checked out good yesterday so I'm ready for whenever the rounds of hay arrives. Today I'll move/shift whatever horse jumps/obstacles are out there so that the semi can move freely... if it can fit through the gate (width-wise). 😐
I'll also need to nip into town as the Wine Faeries have been active again. Oh, and I've got a Doctor appointment @ 1500.
/ Good morning!!!! #216,973
If the semi bringing your hay is 2.5 meters wide (legal)and your gate is 3 meters wide then he/she will have zero problems.
The semi's width is not the concern, it's the width of the load.
Hay rounds, on their side and two abreast will overhang enough on each side of the trailer to cause a problem.
/ Good morning!!!! #216,974
Good Tractor Evening,
BUT I do also have 2 of the LDG 600pro tuners and they are great as well
Steve, I have the LDG 600PROll Tuner on back order, it’s gotten excellent reviews. But it supposedly not getting shipped until February 9 th. I will be laying on a beach in the Caribbean from February 2nd to the 14th. Guess I will evaluate it when I get home. I just like the idea of an Auto Tuner. 😉
Cold cuts that have no comparison here
Massey, I remember being in Venice a few years back, and we stayed at a B&B off the beaten path, every morning they had some of the most amazing meats for breakfast 🙏
/ Good morning!!!! #216,975
68°F and 0 rain
Prayers for all
Be safe
Good luck on that!
/ Good morning!!!! #216,976
Hopefully the brushfires will be quelled and some rain will come. We need rain all over Texas right now too.
/ Good morning!!!! #216,977
Good evening all. 66ºF for the start, partly cloudy, very windy. Windy, partly cloudy sky, and high temp was 67ºF, low at midnight, forecast to be 54ºF. made coffee to start day, no bike ride, worked on office stuff. Christmas decoration down and put away inside, outside lights still have to come down. Did get nap in.
Drew sorry you couldn't get back to sleep. Hope lunch went well.
Phil sorry about pain keeping you awake. Prayers for your sister, that she heals with minimum of pain. Hope clean up of workshop went well. Hope your project did well in contest.
Ron sorry day did not go as planned. Glad you got nap in, then got new mount finished.
Buppies sorry precious decided to bark at whatever. Sorry Holly took off again, glad you got her.Hope you got your nap. prayers set.
Scott(vt) thanks for the compliment. Sounds like you found a very cool friend radio operator.
Bill hope you had good energy conservation.
Billy glad you gave it a squirt. Arm feel better? I have been know to blow out filers like that.
Spike sorry no rain in site. We were supposed to get rain later this week, but forecast accumulation dropped from .5 inch to .1 inch, not looking good either. Hope you get rain soon.
Thomas hope you enjoyed the game.
Happy(nc) compressor doesn't look good at all. Hope you can cobble something together.
ArlyA sorry about the dog alarm. Hope trip home went smoothly.
Drew sorry didn't watch as much science fiction back then.
Mike hope you got your coffee and animals situated.
Frits glad you got coffee pot cleaned up. Sorry Cody fur an issue.
Paul glad you got out before Maduro got there. Hope you get shop and bench cleaned up to start building speakers again. Nice your trash finally got picked up.
Dennis thanks for pie pricing in Caribbean.
Kyle sorry about power loss and computer problems. Glad total power down and reboot worked. Just make sure HD controller can handle SSD.
Two_Bit hope church was good.
Ken have fun playing with Arduino board. Sorry to hear dog had another seizure. Hope Dr visit went well.
Peter(tug) hope visit with friend went well. Hope ABS gremlin doesn't come back soon. Hope fence repair goes well.
Frits glad generator ready to go. Sorry you are having issues with 261C saws. Fuel in first pic looks bad. If you hit plug with propane torch can be tried much quicker. E0 gas plus Marine Stabil works real well for me. (Stihl 017 two weed eaters plastic carb B&S mower)
PJ glad having the foster dog was a success, and now wife has here quilting machine area back. Hope you got your rain, we need some here in Texas!
RS still making good progress on utility room. Hope your Sunday went well.
Fritz glad old 261 fired up after getting compression release working. Have to wonder if fuel in new saw had fuel stabilizer and didn't used ethanol free gas.
Thomas glad you didn't get bored. Sorry about finding icy stop the hard way. Congrats to Giants for the win.
PJ sorry about the trouble with the deer.
Randy(wag) I got my inside decorations down and put away. Outside lights still on gables but the power and controls are off and put away. Hope branches were an easy cleanup.
Dennis glad good trip to B&B in VA. Hope you got your lights down.
Two_Bit glad good church service. Hope granddaughter was as much as as my great granddaughter.
Peter thanks for story on slope slickness on CA.
RS glad demo went smoothly in laundry corner. Hoope your mods went smoothly and were able to get sink, washer, dryer back in operation.
Monday
Ron good to hear bird feeder mount complete. Glad you could help neighbor with front seals and your tractors are the same. Nice cardinal
Bill hope plowing went well.
Scott(vt) hope work went well in the cold.
ArlyA nice snow pic. Hope you break your record.
Billy glad nice hike and swim. Hope coffee was good.
Buppies hope it warmed up for you. Prayers for you and Holly.
Thomas sorry to hear hip injury slowing you down. Hope you got your agenda done and heal fast!
Happy(nc) hope replacement compressor works well.
Mike hope not your dog did well at vet. Hope Christmas celebration was good.
WinterDeere deer population seems to be a problem across the US. Sorry about your brother ad the elk. Nice pic
Engineer nice pic.
Ken hope Dr visit went well.
Dennis congrats on fiber, the only time I loose Internet is when a cable gets cut. Hope the installers work with you.
Paul that online course sounds dumb. Hope the cutting edge went well. Sorry about 16 more hours of frustration.
Lou hope you find an edge for decent price.
Frits glad wood and ash handled. Sorry wood heat not more even.
David glad good afternoon watching football with son.
Lou nice turkey pics
Friend(trac) sorry about meeting, had a few of those myself. Glad tree work went well, and you set up some appointments to view property.
RS hope you got drywall in basement, and supply lines redone.
Peter(tug) glad welding went well.
Dennis hope you get the site working. I had to work on wife's pension site and Diabetes site. Pension site worked well one I read the directions correctly, and the other site will fix problem and let me know when it's fixed.
RS sorry about equipment failure half way through the drywall transfer.
Thomas glad good day, hope Dr visits went well.
Bill hope oil purchase and Dodge repair work went well
more catch up later
prayer for all, especially Jay/Peg, Kyle /Daughter, /mom's breathing, /son's migraines, Mike /BIL in FL, Ron /heart, David(moss) /remodel, /divorce, Buppies /cancer, parathyroid, blood sugar /wife, Thomas /gout, Phil /reflux, Frits /veteran son with mental issues, /granddaughter with Evans Syndrome, Ken /chronic fatigue, Diet not working, Randy(wag) /sister stoke, Scott(vt) /wife's back pain, Don, / BIL motorcycle accident, Steppenwolfe /son-auto immune disorder, Grev /wife's eye, Ted /knee recovery, /retirement & disability red tape, /family issues, /wife back issues and cancer, Lou /eye issues, /heart issues, /wife hip replacement, Doug and wife/health issues, / hand nerve and surgery, /fall and recovery, / wife headaches and heart eval, / David(sadamo)/Sophie's hip or leg pain, Eye recovery, /back issue, Scaredy/shoulder dislocation, /marriage dissolving, / friend stop drinking, Dennis /neighbor issues, /brother's lymphoma, /dad surgery recovery, Drew /back operation issues, /friend's wife cancer diagnosis and recovery, Scotty /back pain, Helogabals /wife's friend situation, Fatjay /father broken hip, Ukraine war, and Country.
/ Good morning!!!! #216,978
Good morning, the low temperature is 38 and going up to 45°F. Wind SE 15 gusting to 22 mph. Rain.
Been raining most of the night. The roof over my bedroom releasing its' snow load woke me up a few minutes ago. There was only about 14" on it. The joys of a steel roof.
I guess this is going to be the end of our January thaw. It'll get colder tonight and snow, 60% chance.
Today is the weekly dump/town run. I surely hope the car wash is open in Sundridge, the car needs it badly. It is one of those DIY deals, pay $3.oo and get three minutes of pressurized water. Right now my black car is black over white (salt & Magnesium Chloride).
I have to pick up more goobers at the dope store today. Grace Slick (R.I.P.) had it right. The pills that mother gives you don't do anything at all.
Time for breakfast.
Stay safe all
/ Good morning!!!! #216,979
Coffee is brewing. 50° with rain this morning. Heading to 58° with clouds and winds. Grocery shopping with went good yesterday. When I got them put away. The sun was out. Did yard cleanup. One side of garden pond that is covered with net does not get much sun this time of year. So no net removal. Maybe today. with the rain and wind and almost 60° temperatures will get it melted. Had a good talk with Drain Commissioner yesterday. I think I have him understanding I am in only one Drain District. He will be here today to go over my and neighbors land and decide which district we belong in.
Cleanup crew is doing a good job of cleaning up under bird feeders.
Everyone stay safe and well.
Good Morning All.
/ Good morning!!!! #216,980
Good Tractor Morning,
Ct, 29 to start going to 49 maybe.
Looks like rain coming in late afternoon or early evening.
This morning we are bringing in Kathleen’s 2020 Honda CRV for service work and a recall. We got the recall notice a couple of months ago and I honestly can’t remember what it was for. Also an oil and filter change and the fluid in the rear and needs changing. We will drop the car off around 8:30 am and pick it up later this afternoon.
Tonite it’s beer and pizza with our friends. Not very often do I post before Drew, he must be sleeping in this morning 😉
I pray for all who have spouses that are sick or incapacitated in some way this morning 🙏
Yesterday was an absolutely beautiful day, although I worked all day it was a joy to be outside in weather like that 🙏 Billy I’m guessing that you and Della went hiking if it was anything like the weather here in Ct 🙏
Hope all have a blessed Friday and Great weekend 😉
2022 North Star Pressure Washer (A60352)
2022 North Star...
John Deere 25A Flail Mower Tractor Attachment (A59228)
John Deere 25A...
2023 MADJAX GENESIS 300 ELECTRIC CART (A57192)
2023 MADJAX...
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A58216)
2013 ORTEQ ENERGY...
159116 (A60430)
159116 (A60430)
2022 RAM 2500 HEAVY DUTY (A55745)
2022 RAM 2500...
