etpm
Veteran Member
- Joined
- Jun 30, 2021
- Messages
- 2,355
- Location
- Whidbey Island, WA
- Tractor
- Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
I'm going to be the one guy who doesn't like auto darks.... I've had probably 5 of them (miller/Lincoln, not even cheap ones) and they've all been nothing but trouble. Even the ones that didn't break were just a pain in the neck for what I do.
I would agree that for typically hobby use they are great. Welding things on a bench, ect
My issue is largely working on equipment in awkward places and blocking the sensors with pieces of the machine, hydraulic hoses, ect.
And then the constant running out of batteries when you are not at the shop, ect.
I finally went and bought a few of the old flip-down fibre metal pipeliner hoods, and keep a different shade lens in each one. A side benefit is I've found you have better clarity with a gold coated glass lens than with the auto dark filter.
Now a cheap flip down hood is going to be infuriating. And those fibremetal ones cost the same as or more than an autodark. But they are comfortable, and they work effortlessly and reliably. Once you get used to the slight nod before striking an arc it's really no less user friendly than an auto da
Well, it's unfortunate you have had so much trouble. My HTP hood is very good on batteries, has solar cells that also power it, multiple sensors so that I never block them all, excellent, and I mean excellent, clarity, just as good as the plain lens types, and is lightweight. I too had trouble with early auto-dark hoods and would often switch to a plain lens hood, but no more. and even though I learned to arc weld over 30 years ago using the old style hoods, like everyone else, when I teach others how to weld I can see just how much easier it is for them using auto-dark hoods.I'm going to be the one guy who doesn't like auto darks.... I've had probably 5 of them (miller/Lincoln, not even cheap ones) and they've all been nothing but trouble. Even the ones that didn't break were just a pain in the neck for what I do.
Now a cheap flip down hood is going to be infuriating. And those fibremetal ones cost the same as or more than an autodark. But they are comfortable, and they work effortlessly and reliably. Once you get used to the slight nod before striking an arc it's really no less user friendly than an auto dark.
Eric
