Getting Back Into Welding
/ Getting Back Into Welding #1
jaydee325
Casco, Mi
John Deere X584 Garden Tractor & LS R3039H
Last time I struck an arc was at least 40 years ago. I'm retired now and would like to get back into it as a hobby. Planning on staying with stick as that is what I know.
Anyone been in the same position? What was your experience striking that first arc again? I'm hoping it's a lot like riding a bike in that you don't forget!
/ Getting Back Into Welding #2
It was a little like riding a bike:) My eyes aren't as good, but lots of light and cheater glasses help. Happy to report I am still as bad as I was in high school, I have gotten a little more patient, so probably a little better grinder..........
Best,
ed
/ Getting Back Into Welding #3
I too started stick welding after about a 40 year gap. Bought my tractor 8 years ago and bought a stick welder soon after.
I got a lot of great advice right here on TBN , especially from Shield Arc (RIP.....sure do miss him!) Also welding tips & tricks on YouTube is good. Get some scrap and start burning rod, you'll get it
/ Getting Back Into Welding #5
After I bought a Miller 211 MIG machine, my Miller Thunderbolt AC/DC macine just collected dust. A friend borrowed it a couple times when his buzz box died, but a year ago I sold it on CL. I have a Eastwood TIG 200 that will do stick welding if I would need a stick machine, but I don't see the need anytime soon.
/ Getting Back Into Welding #6
It's hard to beat AC/DC stick for versatility. I don't use mine often, but it's a real asset when I do. I own several welding machines - Mig, Tig, stick, and an engine-driven Bobcat 250. but I'm not a pro. I'm just a guy who likes to build and modify stuff. I also like having the right tools for the job. If I'm doing a lot of lighter-duty welds, I'll grab my MM210 Mig every time. For repair work on heavier steel, it's usually stick. In the field, it's almost always stick, but the Bobcat can power the MM210 if needed.
/ Getting Back Into Welding #7
OP: cool we can revisit a skill we've known in our youth. have you looked at equipment possibilities yet for your return to arc?
I have been looking at equipment. A ways off from a purchase yet. The nice thing about the current equipment is that it has multiple options for expandability. I can work my stick skills back to the high standard I possessed (well, hopefully!), then I can buy the add-on's to delve into MIG or TIG.
TIG and welding aluminum always intrigued me, so this could be something I'd try down the road.
This is all going to start at a basic hobby level.
/ Getting Back Into Welding #9
good plan. lots out there for multiple options on a single machine. am sure you'll get useful responses
strictly arc here, well pleased with my Hobart upgrade from Lincoln tombstone. keep the forum informed along the way, best regards
/ Getting Back Into Welding #10
I recently bought a https://www.amazon.com/dp/B084PY4C5...=NUgU8&ref_=sbx_be_s_sparkle_mcd_asin_0_title to use as a dedicated Tig unit, but it also does stick. I'll never use it for stick, but it was the best-reviewed offshore brand I could find for Tig. Called and spoke with the importer. If you want one, get on the waiting list early - he sells out a shipment very quickly. Impressive machine, and will probably last me the rest of my life. NOT a lightweight, though - but fits on the better Harbor Freight Vulcan cart like it was made for it. 350 lb. Capacity Welding Cart
/ Getting Back Into Welding #11
I enjoy learning something new, so a few years ago I bought one of the multipurpose machines so I could dabble with MIG. I think I have used stick a couple of times since I have had the new machine, but I could probably do with out stick welding altogether without much trouble.
/ Getting Back Into Welding #12
If you get back into it, consider looking for a used engine-based stick welder so you can bring the welder to the job, rather than the job to the welder. Just used an older Miller Blue Star yesterday to weld chain hooks on a bucket using 7018 rods.
/ Getting Back Into Welding #13
Second this with a twist. I got back into welding because the best generator I could find for my needs was miller 300 that doubles as a welder.
Worked out great and doesn't sit for months at a time waiting for the lights to go out.
Best,
ed
/ Getting Back Into Welding #14
I have been looking at this one for a combined welder/generator. It will be stick until I get bored or need something else. This will also double as a back up house generator. As I understand its almost the same as the Miller but $2000 less.
/ Getting Back Into Welding #15
That's a great unit, and will do fine for most fabrication and repair tasks. I bought my Miller Bobcat 250 about twenty years ago, and looked hard at the Hobart at the time. I decided to buy the Miller, and never regretted it. Probably would have been just as happy with the Hobart for welding, but the generator on the Bobcat was cleaner output. I don't know if that's still true on current models.
Regardless of which one you get, buy an extra fuel pump. They're the weakest link, thanks to the ethanol in most gasoline. I get 3-5 years out of mine, then they fail. The cheap ones out of China seem to hold up about the same as the ones that cost 5x as much. Takes about ten minutes to swap one out, if you go slow and have one on hand.
/ Getting Back Into Welding #16
About 10 years ago I stopped using the crap-ahol gas on everything but road machines - about a buck more a gallon, and I pay it GLEEFULLY, 'cause I know I'll probably NEVER have to replace a carb or fuel pump in my lifetime - only thing I don't use no-E gas in is tractors and backhoe, 'cause they'd EXPLODE if I did (Diesels tend to do that if you forget) o_O... Steve
/ Getting Back Into Welding #17
I am proficient in stick, MIG, & TIG. I mostly TIG weld, next is MIG, and then way down the list is stick. That said, stick is the most versatile for the least money when it comes to welding iron alloys. And yes, you will pick it up fast. You can usually buy just a pound of rod for stick welding when there is some special need. Like welding cast iron or stainless steel. Your stainless stick welds won't be as pretty as TIG welds but will be way cheaper. One thing has changed greatly since you first welded. Hoods. You absolutely should buy an auto-darken hood. These days you can buy an excellent auto-darken hood, with the shade adjustable from what would be comparable to light sunglasses, so you can do work like grinding with your hood down, to the darkest of shades. And you get all this versatility, plus a larger viewing area than your old hood, plus being lighter than your old hood, for about $120.00. Tomorrow I will post the name of a great hood, the one I use most. I would do it now but my old brain can't remember the name of the company.
Eric
/ Getting Back Into Welding #18
I'm going to be the one guy who doesn't like auto darks.... I've had probably 5 of them (miller/Lincoln, not even cheap ones) and they've all been nothing but trouble. Even the ones that didn't break were just a pain in the neck for what I do.
I would agree that for typically hobby use they are great. Welding things on a bench, ect
My issue is largely working on equipment in awkward places and blocking the sensors with pieces of the machine, hydraulic hoses, ect.
And then the constant running out of batteries when you are not at the shop, ect.
I finally went and bought a few of the old flip-down fibre metal pipeliner hoods, and keep a different shade lens in each one. A side benefit is I've found you have better clarity with a gold coated glass lens than with the auto dark filter.
Now a cheap flip down hood is going to be infuriating. And those fibremetal ones cost the same as or more than an autodark. But they are comfortable, and they work effortlessly and reliably. Once you get used to the slight nod before striking an arc it's really no less user friendly than an auto dark.
/ Getting Back Into Welding #19
Best,
ed
Exactly what I did, was looking for a generator and welder during the same time period. Found I could get a much bigger quality generator for the same money that doubled as a welder. It was a no brainer.
/ Getting Back Into Welding #20
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
MultiQuip 9700 Portable Gasoline Generator (A64553)
MultiQuip 9700...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
2005 SBX-5 Box Blade Tractor Attachment (A61572)
2005 SBX-5 Box...
2013 Ford Escape SUV (A64557)
2013 Ford Escape...
WOODS TS1680 - 14' ROTARY MOWER, 3PT (A64278)
WOODS TS1680 - 14'...
