Generator Wiring Question.
   / Generator Wiring Question. #21
techman,
Can you please give me a little more info on the Square D panel you mention with the interlock. I have been looking for a way to power my house during black-outs. One problem I have is that I have 200 AMP service with TWO breaker panels.
So I would have to use two of the Square D panels you describe. Do you have a model number or anything that will help me out?
Thanks, Tim
   / Generator Wiring Question. #22
</font><font color="blue" class="small">( Would that not involve pulling the main and rerouting the feed for the installation?)</font>
Yes, in my case I'll be doing it as part of the original wire up of the house.......
   / Generator Wiring Question. #23
SQ D makes a few varieties. The one I had seen I can not find a picture of. Here are a couple of different types you could look into:
http://www.interlockkit.com/
http://cgi.ebay.com/SQUARE-D-QO-GENERATOR-TRANSFER-SWITCH-200A-LOAD-CENTER_W0QQitemZ7582736048QQcategoryZ46412QQrdZ1QQcmdZViewItem
The attached picture is what I did. I made my own bracket out of some aluminium stock. The sloted holes run over some round stock that is fixed by the two screws. The center screw actually has a small standoff that is a handle to move the lever. As you can see the main must be off to turn on the gen feed breaker and vias versa.
paul
As always, I really appreciate all of the advice/suggestions that you guys give on this site. After much debate, I decided to purchase this;
Reliance Power Transfer Kit for Portable Generators (10 Circuit)
BTW, they (Generatorsdirect.com) happened to be the cheapest that I could find.
Since there are times I'm away from home for extended periods, I wanted to be sure that everything was simple and safe for the wife to use.
Thanks again.
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
International S1900 (A56436)
International...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
SUV (A59231)
SUV (A59231)
1994 HEIL BULK TANK TRAILER (A59575)
1994 HEIL BULK...
(APPROX. 480BF) 1X6X6-16 WHITE PINE TONGUE & GROOV (A52706)
(APPROX. 480BF)...
