Generator Wiring Question.
/ Generator Wiring Question. #21
techman,
Can you please give me a little more info on the Square D panel you mention with the interlock. I have been looking for a way to power my house during black-outs. One problem I have is that I have 200 AMP service with TWO breaker panels.
So I would have to use two of the Square D panels you describe. Do you have a model number or anything that will help me out?
Thanks, Tim
/ Generator Wiring Question. #22
</font><font color="blue" class="small">( Would that not involve pulling the main and rerouting the feed for the installation?)</font>
Yes, in my case I'll be doing it as part of the original wire up of the house.......
/ Generator Wiring Question. #23
SQ D makes a few varieties. The one I had seen I can not find a picture of. Here are a couple of different types you could look into:
http://www.interlockkit.com/
http://cgi.ebay.com/SQUARE-D-QO-GENERATOR-TRANSFER-SWITCH-200A-LOAD-CENTER_W0QQitemZ7582736048QQcategoryZ46412QQrdZ1QQcmdZViewItem
The attached picture is what I did. I made my own bracket out of some aluminium stock. The sloted holes run over some round stock that is fixed by the two screws. The center screw actually has a small standoff that is a handle to move the lever. As you can see the main must be off to turn on the gen feed breaker and vias versa.
paul
As always, I really appreciate all of the advice/suggestions that you guys give on this site. After much debate, I decided to purchase this;
Reliance Power Transfer Kit for Portable Generators (10 Circuit)
BTW, they (Generatorsdirect.com) happened to be the cheapest that I could find.
Since there are times I'm away from home for extended periods, I wanted to be sure that everything was simple and safe for the wife to use.
Thanks again.
207272 (A52708)
207272 (A52708)
2022 FORD F-750 SUPER DUTY DUMP TRUCK (A63276)
2022 FORD F-750...
2018 KAUFMAN GOOSENECK TRAILER (A63290)
2018 KAUFMAN...
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
Lift cylinder for model 48 john deere loader
Lift cylinder for...
2025 Polaris Ranger XP1000 (A60462)
2025 Polaris...
