Generator Selection?
/ Generator Selection?
ATS is in. Geeze what a cluster. ATS part was fine. Pretty straight forward. Everything else ... well ....
For starters the fancy schmancy 2/0 I bought is now scrap. $50 or so wasted. It was too large to fit into any of the breaker lugs, so after I had it all cut and run through the conduit, I couldn't make any of the connections with it. Had to pull it all out and try to re-use the old 2/0 I had. Combined with the one piece of #2 THHN, I got everything reconnected and energized, but it won't be able to stay this way. It will have to be re-done once I figure out what I need to do. Buy more #2 THHN I guess.
Unhappy? You betcha.
/ Generator Selection? #262
What is schmancy 2/0? Copper wire? If too big for lugs just cut some strands off. Why did you buy such big wire for 100 amp service?
/ Generator Selection? #263
/ Generator Selection? #264
Honestly, a 100 amp switch is not designed to handle 2/0 wire. That sized wire is way oversized for a 100 amp system.
^^^ See, that's the problem I've been running into that no one seems to get. I have 2/0 installed and have since 1998 when I did this panel and meter upgrade from 60 to 100A. It all worked well and fit into the conduit and breaker lugs with no problem. Sometime since then, they changed the specs for 2/0. It's now much larger diameter and has 19 finer strands instead of the 7 heavier strands I have in the older wire. The stuff you get now is probably 30% larger diameter and will no longer fit where my older 2/0 would.
/ Generator Selection? #266
They have not change the spec's post some pics, somebody sold you the wrong wire
/ Generator Selection? #267
Within the same gauge of wire I have found variation between stranded and solid and also the thickness of the insulation depending on what comprised it.
I still have 12 gauge in Knob and Tube with loom... so there are variations over time as materials improve.
/ Generator Selection? #268
That is weird. I have tied new 2/0 into real old 2/0 and have never noticed any differences. nowdays, the outside insulation is thinner due to advances in insulation, but wire size has never changed. Not sure whats happening on your end.
/ Generator Selection? #269
Is there more variations between solid and stranded as number of strands...
There is stranded and there is stranded... one is a bundle of smaller gauge and another a bundle of very small gauge to increase flexibility...
Just guessing here.
/ Generator Selection? #270
We need pics, I'm sure the labeling on the wire will clear this up.
2020 DRAGON ESP...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A62129)
2007 CATERPILLAR...
UNVERFERTH 330 - 19-INCH EXTENSION KIT FOR RIP-STRIP TOOLBAR PART # 63186G (A55315)
UNVERFERTH 330 -...
2004 VE ENTERPRISES 500BBL FRAC TANK (A58214)
2004 VE...
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
2020 BOBCAT T770 SKID STEER (A62129)
2020 BOBCAT T770...
