IH3444
Elite Member
- Joined
- Jan 10, 2004
- Messages
- 2,644
Hello LouNY, I'm trying to decide between Kubota LX2620 Cab and the Kioti CK2620SE Cab w/loader. I just got a quote on a leftover 2024 Kioti CK2620SE Cab with R14 tires so I was wondering what you paid for your Kioti? I also have a Kioti CS2520 60" mower just for moving and so far, am happy with it. Thanks, IH3444Good update, glad your Kioti is working out for you.
I picked up a CK2620SE with the cab and AC last summer.
One reason I went with the 2620 is the 25 hp limit to avoid a doc/dpf in the exhaust and emission compliant common rail fuel injection.
I also will be turning the fuel screw up mine. I did get the little backhoe and while I have used it quite a bit I'm still debating with myself the usefulness of the backhoe compared to one of the chinee mini excavators for about the same money.
I am pleased with the R14 tires, I did have to add spacers to the rear for tire chain clearance.
Also I use the mid range most of the time but it will run out of power quite rapidly some times.
My driveway is steep and she can travese the entire thing with the AC on in low range with no trouble, in mid range I end up with the hand throttle maxed out and feathered most of the way out on the speed pedal to keep her above 2200 rpm in a few spots and if I'm in a hurry I'll turn the AC off for a hundred feet of the steepest.
I am going to have to put a seat riser or a stiffer spring in the seat to raise my seating position and have to watch my right knee as it has curled the bucket a few times when I wasn't paying attention.
