Oil & Fuel Fuel Transfer Strategies
   / Fuel Transfer Strategies #41
Hmmmm are you saying then that air might not be such a good idea after all? /forums/images/graemlins/crazy.gif
   / Fuel Transfer Strategies #42
no water in my tank because of the air . i use the air for the air tools & they don't like water. so there is a filter in line before the desiel. without that you still should not get any with a filter on your outlet of the fuel tank. i learned desiels need clean fuel . that is why i don't use jugs & carry fuel. run with low pressure so the filter does its job & change when needed. . it works great for me.
   / Fuel Transfer Strategies #43
Well transferring combustible liquids by air is permitted by Code, NFPA 30, 2003 edition, see below.
7.3.7.4 Transfer of liquids among vessels, containers, tanks, and piping systems by means of air or inert gas pressure shall be permitted only under all of the following conditions:
(1) The vessels, containers, tanks, and piping systems shall be designed for such pressurized transfer and shall be capable of withstanding the anticipated operating pressure.
(2) Safety and operating controls, including pressure-relief devices, shall be provided to prevent overpressure of any part of the system.
If you know what pressure the drum can withstand AND you have a pressure relief valve you can do it.
Diesel is a class II combustible liquid. BUT if you spray it and cause it to atomize i.e. from a drum lid pooping off, it will lower the flash point and any source of ignition will result in a ball of fire. Hopefully you or anyone from your family is not around when this happens. Of course this always happens to the other guy. /forums/images/graemlins/frown.gif
OK work hat off now. /forums/images/graemlins/grin.gif
   / Fuel Transfer Strategies #44
</font><font color="blue" class="small">( Mike,
I installed a male air line quick coupler into the 1" bung in the 55 gallon drum I was using for my fuel storage. Run the regulator on my shop air lines down to 5 psi, hook a line to the quick coupler on the tank, stick hose in the tractor's fuel tank and open the shutoff valve on the hose and away you go - it works very well. If I had known how well I could have saved the $90 I spent on a good GPI hand pump at TSC. /forums/images/graemlins/grin.gif
I'd say the only thing you have be careful of is the pressure - dunno what a 55 is rated for, but I'd think that 5 or 10 psi is within safe limits. I always uncouple the air line immediately after I close the valve.
When I'm done I cover the end of the QD with a plastic automotive vacuum cap. It's amazing to me how much pressure that vacuum cap will keep in the tank with just a friction fit. )</font>
Boy howdy, we used to transfer oil out of drums to storage on the battleship with air pressure. We didn't have a regulator! We had one gomer on the valve at the other end of the hose. One time, the dummy wasn't paying attention and we got who knows how much pressure in the drum. The bottom and top punked out like a ball park frank, scared us to death! Master Chief was already having kittens about the spillage on the teak!
I've seen drums go on safety videos, nuh-uh, no way, not in a million years, especially with fuel.
   / Fuel Transfer Strategies #45
John,
</font><font color="blue" class="small">( Any sign of water from the compressor in your fuel?
)</font>
Not as far as I can tell - I have an auto drain valve on the compressor tank itself, a Schrader-Bellows water separator/filter just before the hose reel, a drop trap on the line just before that.
   / Fuel Transfer Strategies #46
</font><font color="blue" class="small">( A quick pie,r, squared calc gives a 2 foot diameter barrel an end area of 452 square inches. Ten PSI gives you 4500 pounds of force from compressed air. Figure the crimp on the end of that barrel holding the thin lid on is withstanding enough pressure to lift up a full sized truck. )</font>
Good data and a good point. When I initially started doing this I would only apply the air long enough to get the fuel up the intake line to the hand pump and then I would pump it until I had filled the tractor. At some point I got a little lazy and just let the air do the work - sounds like that might not be a real good idea.
The missing data would be "What are 55 gallon drums rated for, pressure-wise ?" And after that, factor in barrel age, abuse, etc.
   / Fuel Transfer Strategies #47
I agree. Both the fireman's post and rswyan's point out that we do not know what pressure a barrel is rated for. This is critical. The right pressure vessel would make this much safer.
If the barrel and the bunghole connections can take 10 psi then great, you could lift fuel more than 23 feet vertically. 3 psi gets you more than 7 feet. I used pressure from a water column for the calc where 1 psi is equal to 28 inches of water.
A guy could add the air with a hand pump to be safe. Gauges that read less than 10 psi with any dream of precision are rare but 3 psi should be plenty for most uses.
Why don't we do an experiment? Some fill a barrel half full of water and then run their air hose to it, a long ways away, and keep adding pressure until it blows. I bet it would be fantastic and since steel barrels are free and completely recycleable..... It could be a game like guessing how many jelly beans are in the jar.
   / Fuel Transfer Strategies #48
Go for it Highbeam.... let us know how it works. Makes sure you run up to the barrel and check the pressure every minute so we are sure to get a good reading when she blows. /forums/images/graemlins/smile.gif
   / Fuel Transfer Strategies #49
Knowing my luck, the dang barrel would just balloon up and sit there with full air pressure from the compressor. Then I would be forced to throw rocks at it and then shoot it until it blows.
   / Fuel Transfer Strategies #50
After reading the post by v8dave, I realize I've already got the tank - my home heating oil tank. I would just need to plumb up a pump on the side of my house. The tank is in my basement so I have good access. Anyone have thoughts on this?
2015 Chevrolet Tahoe SUV (A55853)
2015 Chevrolet...
2012 Western Star Trucks 4900 SA Truck, VIN # 5KJJALDV0CPBE2239 (A57453)
2012 Western Star...
Year: 2005 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55788)
Year: 2005 Make...
2020 DRAGON ESP...
2008 Ford E-350 Altec AT200AV 30ft Bucket Van (A56858)
2008 Ford E-350...
2018 John Deere 30G Mini Excavator (A56857)
2018 John Deere...
