front tire size question
/ front tire size question #1
joeu235
Platinum Member
Little River, TX
John Deere 4020 / 6403 / 317 Ford 5600
My Ford 5600 has 10-16.5 skid steer tires on the front and I want to switch back to ribbed tires because the steering in mud is terrible.
The owner's manual says 10.00-16 tires were originally an option. Do you think 10.00-16 is what the rims were originally designed for and will they fit?
Thanks
/ front tire size question #2
Hopefully if it has 16.5 inch tires on it it has 16.5 inch rims. You will need 16 inch rims for 16 inch tires. Rim size is usually stamped on the visible surface of the rim (not the center disc).
I found the stamp. 16.5 x 8.25. I can't imagine these are original rims. Thanks!
2020 GMC AT4 CREW CAB TRUCK (A62130)
2020 GMC AT4 CREW...
2005 Peterbilt 379 Extended Day Cab (A62613)
2005 Peterbilt 379...
2010 MACK PINNACLE (INOPERABLE) (A63569)
2010 MACK PINNACLE...
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2016 Chevrolet...
New Holland TC35D Tractor w/ Loader (A64047)
New Holland TC35D...
Bobcat 72" Rotary Cutter (A64047)
Bobcat 72" Rotary...
