Buying Advice Friend needs to replace a Kioti CK30 due to rotary cutter "bush hog" weight
   / Friend needs to replace a Kioti CK30 due to rotary cutter "bush hog" weight
Can you walk up it? If so it isnt much over 30degrees.
I have walked up it before, but it was rather tough as I was almost crawling up with the grade.
I didn't see anywhere if the mowing is up/down or you expect to mow sideways on a 45 degree slope.
I know someone who has rolled a tracked skidsteer on two separate occasions. Both on slopes much less than 45 degrees.
No, up and down, not sideways. Way too steep to mow sideways.
   / Friend needs to replace a Kioti CK30 due to rotary cutter "bush hog" weight #33
Sounds like what I mow up/down with my bar tired BX1500. I measured it at 30 degrees. Also a steeper area -- est ~33 -- that it wants differential lock to climb unless youre pointed straight up/down
   / Friend needs to replace a Kioti CK30 due to rotary cutter "bush hog" weight #34
I've thought of buying an Inclinometers for my tractor just for the curiosity factory ...
I know there is a vast difference in how slopes are measured ... Angle, degree, percent ... This is about as steep as my "Butt-O-Meter" would let me go ... And when I got off, I tried ... And couldn't even budge it!!!
The picture isn't quite level, it's a tad steeper ... The Trees are vertical ...
Here are a whole bunch of styles ...
Inclinometers | Slope Grade Degree Indicator For Sale | R&B MFG. INC
   / Friend needs to replace a Kioti CK30 due to rotary cutter "bush hog" weight #35
It’s stable until a wheel drops into a hole.
   / Friend needs to replace a Kioti CK30 due to rotary cutter "bush hog" weight #36
From that page, most of them don't go to 45 degrees... but one in the middle is U-shaped, and should work up to 90 degrees... just in case you need it.
There are also digital inclinometers that you can use. I think even a cell phone app. Just bring a 2x4 to smooth out the bumps in the slope and measure with your phone.
Or for percent slope, it is just rise over run. Bring your level. One end on uphill part of the slope, measure from the other end down to the slope. Then rise over run and you get the percent slope.
   / Friend needs to replace a Kioti CK30 due to rotary cutter "bush hog" weight #37
My slope will be more or less perfect. I peak at about 45°. I have a side slope that is closer to 20°. There is a short 10' or so tall bank that goes the whole length, but there appears to be an ancient road cut that goes down over that bank to a narrow level area.
So I should be able to make a path to plunge down the 45° slope. Level out at the bottom. Hang a left, 100 yards, and up the old road cut to a level spot at the bottom of that side slope. Then back up to the top to try again.
Unfortunately everything seems like a compound angle, but that may simply be a perception based on apparent edges that I can observe. So it will take a little practice to find that perfect straight down slope.
Bonneville Power cut down some Maple trees up to about 8" in diameter, and left them in the middle of the blackberry patch, so they will be fun to mow.
   / Friend needs to replace a Kioti CK30 due to rotary cutter "bush hog" weight #38
My friend bought a 5' Everything Attachments heavy rotary cutter, aka Bush Hog, and has been using it with a compact Kioti CK30 (think that is the correct model number). While it was a good tractor with the lightweight, disposable Kioti rotary cutter, it isn't really safe around his dam and is generally poorly 'balanced'.
He needs a compact tractor since he clears trails in trees where the lanes are pretty tight. Looking for a replacement in East Texas via TractorHouse and TractorData, I'm not seeing anything that jumps out at me.
I remember seeing an older Massey 26xx something with a Perkins engine that was an older operating station model, but I can't seem to find it today. Kubota and John Deere rule around here with some Mahindra and TYM support.
What tractor models do EA 5' rotary mower owners have that are appropriate for mowing rough trails and the backside of a dam? I am looking for something safe, as he was lucky to remain uninjured when the Hydrostat starved of oil and he rolled backwards down a big dam. Width and height need to remain reasonable for "walking" trails in trees where he blades rain washouts and picks up downed limbs and cut up felled trees.
Please ignore the AutoCorrect/AI madness in this post ... 😡
I mow the back side of my dam with a Ferris 61" ZT and mow the 30* backside vertically, not horizontally. I have mowed it with a Ford 2000 4 cylinder, regular sized tractor in horizontal directions but decided to quit doing it before I had a problem.
If I were to mow it with my LS 2-25s which I built and installed 4" spacers on the rear it too would be vertically.
The problem with vertical is that you have to have room at the bottom to get stopped coming down and have room to turn around. On coming down the weight is forward giving a light rear and even with brakes it likes to slide if the grass is wet. Going up is just the opposite.....the weight is centered at the rear where the drive/stop mechanism is located and that's a piece of cake.
   / Friend needs to replace a Kioti CK30 due to rotary cutter "bush hog" weight #39
Piece of cake at 30 degrees... Traction is still a problem at 45 degrees.
Make sure you have either a ROPS or FOPS on your tractor.
With my bicycle... I know not a tractor, but going uphill, I can have troubles with too much weight on the rear wheel and unweighted front wheel. Easy to torque wheelie. But the same could be true with a tractor.
I had a neighbor playing around with an older tractor on a hillside, and it rolled over on him. Be careful.
With a brush hog or rotary cutter attached, a wheelie isn't going to happen, other than possibly a few inches before the slack in the mower bottoms out.
2016 Ford F-350XL (A57148)
2016 Ford F-350XL...
2016 Ford Transit 250 Passenger Van (A55852)
2016 Ford Transit...
2022 INTERNATIONAL MV607 (A58214)
2022 INTERNATIONAL...
2021 Deere 331G (A53317)
2021 Deere 331G...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A56435)
Kuhns AE10 Small...
2007 MACK CTP713 TRI AXLE DUMP TRUCK (A58018)
2007 MACK CTP713...
