I didn't see anywhere if the mowing is up/down or you expect to mow sideways on a 45 degree slope.
I know someone who has rolled a tracked skidsteer on two separate occasions. Both on slopes much less than 45 degrees.
Sounds like what I mow up/down with my bar tired BX1500. I measured it at 30 degrees. Also a steeper area -- est ~33 -- that it wants differential lock to climb unless youre pointed straight up/downI have walked up it before, but it was rather tough as I was almost crawling up with the grade.
Itās stable until a wheel drops into a hole.I've thought of buying an Inclinometers for my tractor just for the curiosity factory ...
I know there is a vast difference in how slopes are measured ... Angle, degree, percent ... This is about as steep as my "Butt-O-Meter" would let me go ... And when I got off, I tried ... And couldn't even budge it!!!
The picture isn't quite level, it's a tad steeper ... The Trees are vertical ...
Here are a whole bunch of styles ...
Inclinometers | Slope Grade Degree Indicator For Sale | R&B MFG. INC
From that page, most of them don't go to 45 degrees... but one in the middle is U-shaped, and should work up to 90 degrees... just in case you need it.I've thought of buying an Inclinometers for my tractor just for the curiosity factory ...
I mow the back side of my dam with a Ferris 61" ZT and mow the 30* backside vertically, not horizontally. I have mowed it with a Ford 2000 4 cylinder, regular sized tractor in horizontal directions but decided to quit doing it before I had a problem.My friend bought a 5' Everything Attachments heavy rotary cutter, aka Bush Hog, and has been using it with a compact Kioti CK30 (think that is the correct model number). While it was a good tractor with the lightweight, disposable Kioti rotary cutter, it isn't really safe around his dam and is generally poorly 'balanced'.
He needs a compact tractor since he clears trails in trees where the lanes are pretty tight. Looking for a replacement in East Texas via TractorHouse and TractorData, I'm not seeing anything that jumps out at me.
I remember seeing an older Massey 26xx something with a Perkins engine that was an older operating station model, but I can't seem to find it today. Kubota and John Deere rule around here with some Mahindra and TYM support.
What tractor models do EA 5' rotary mower owners have that are appropriate for mowing rough trails and the backside of a dam? I am looking for something safe, as he was lucky to remain uninjured when the Hydrostat starved of oil and he rolled backwards down a big dam. Width and height need to remain reasonable for "walking" trails in trees where he blades rain washouts and picks up downed limbs and cut up felled trees.
Please ignore the AutoCorrect/AI madness in this post ...![]()
The problem with vertical is that you have to have room at the bottom to get stopped coming down and have room to turn around. On coming down the weight is forward giving a light rear and even with brakes it likes to slide if the grass is wet. Going up is just the opposite.....the weight is centered at the rear where the drive/stop mechanism is located and that's a piece of cake.
