Buying Advice Friend needs to replace a Kioti CK30 due to rotary cutter "bush hog" weight
   / Friend needs to replace a Kioti CK30 due to rotary cutter "bush hog" weight #21
Have you considered spraying, maybe a couple times per year instead of spending $90,000 on a tracked skid steer to mow? Yes, you need some vegetation to prevent erosion, but say, 3 sprays per year with glypho, or similar, not a long lasting, soil sterilizer. Heck of a lot cheaper.
That would create bare ground and lead to erosion.
   / Friend needs to replace a Kioti CK30 due to rotary cutter "bush hog" weight #22
The skid steer in question is a tracked model. I don't have a protractor, so ~45 degrees is a guess, not a scientific measurement. Also, he isn't mowing into the water, only mowing the backside of the dam. And yes, the base is reasonably flat.
45* is the same as a 12/12 pitch roof.. Highly doubt that anyone is driving on that in any direction.
   / Friend needs to replace a Kioti CK30 due to rotary cutter "bush hog" weight #24
The general rule of thumb for ground based logging equipment is 40% slope maximum.
And 45 degrees = 100% slope...
Degrees and Percent are not the same. 40% slope is about 22 degrees, which is the same as a 5/12 pitch roof in the pic.
   / Friend needs to replace a Kioti CK30 due to rotary cutter "bush hog" weight #25
Not so much, spraying will kill what's currently growing, but that stuff doesn't go away, and new grasses will be popping back up within 3 weeks. Thats why I said Not a soil sterilizer
   / Friend needs to replace a Kioti CK30 due to rotary cutter "bush hog" weight #26
Just recently, driving through Town of Pomona Park, I saw their couple public works guys had a boom mower mounted on a Kubota L2501. It caught my eye, as I haven't seen one mounted on anything below 75hp below. With that, its Small, and although I see the dam backslooe is Steep, how long is it maintenance berm to toe of slope?
Looking online, just quickly, it looks like there are boom mowers that gk as low as only requiring 3968 lbs of tractor weight.
Actually, as i scroll down, they have ones that get even lighter
   / Friend needs to replace a Kioti CK30 due to rotary cutter "bush hog" weight #27
On slope, i would "assume" its a 3 to 1 slope, thats pretty standard, and is mowable, but your butt hole does grip the seat
Important Edit: I say a 3:1 is mowable, and it is, With a Properly set up machine. I dont want that to imply any tractor, any config, is just safe to use on a 3:1. Stuff like weight distribution, tire set up, ecr is critical. As well as ground condition. In addition, if running cross the slope, a lower tire going into a hole, can pretty quickly change safe but scary to not safe
   / Friend needs to replace a Kioti CK30 due to rotary cutter "bush hog" weight #28
Not my experience with Roundup. It will kill perennial grasses, then just weeds regrow.
   / Friend needs to replace a Kioti CK30 due to rotary cutter "bush hog" weight #29
Correct
   / Friend needs to replace a Kioti CK30 due to rotary cutter "bush hog" weight #30
I didn't see anywhere if the mowing is up/down or you expect to mow sideways on a 45 degree slope.
I know someone who has rolled a tracked skidsteer on two separate occasions. Both on slopes much less than 45 degrees.
12V Diesel Fuel Transfer Pump (New/Unused) (A59225)
12V Diesel Fuel...
2019 Kohler 50REOZK 50 kW Diesel Generator (A56857)
2019 Kohler...
2002 Isuzu NPR-HD Box Truck (A56858)
2002 Isuzu NPR-HD...
John Deere 6ft (A56857)
John Deere 6ft...
2015 DODGE DURANGO RT (A58018)
2015 DODGE DURANGO...
2007 Hyundai Santa Fe SUV (A55973)
2007 Hyundai Santa...
