Buying Advice Fleet Manager
/ Fleet Manager #1
lrwatson
Scottsboro, Alabama
Freightliner
looking to buy an air compressor to fill trailer tires within at 10 to 15 minutes. 295 75R 22.5 would a 30 gal, 9Hp 170 MAx PSI with a CFM of 24 @ 100 PSI do the job?
/ Fleet Manager #2
I don't understand the question entirely? that air compressor should fill a tire to 100 psi no problem.
/ Fleet Manager
I felt it would, it was more of a , "if the tire were at 20lbs, would it fill it up with 100 lbs of air within 15 minutes? I may not have asked it correctly....sorry....
/ Fleet Manager #5
It sure wouldn't take 5 minutes to fill from 20 to 100 psi. You need to set the regulator above 100psi or its going to take minutes for that last 10lbs to fill.
/ Fleet Manager #6
I'm wondering where you've found a compressor with 24 cfm @ 100 psi?
That is one serious compressor there.
/ Fleet Manager #7
I have a engine drive Deere compressor. Made by mi-t-m. It is 29 cfm at 175psi. Puts out a ton of air. 30 gallon tank. I think it would be more than enough for your needs. Has a great Honda too. Elec start gets it going quick.
Brett
/ Fleet Manager #8
I bypassed the regulator for filling tires. Unscrewed the tank pressure gauge, added a tee, cut off valve and a quick connect:
/ Fleet Manager #10
You can if the beads of the tires are touching the walls of the rim. If not get a bead blaster. You'll be all set ��
I have smaller compressior running on 120v in work truck running off generator
/ Fleet Manager #11
Excellent idea! Can you seat beads with it??
Yep, I have. But usually have to tighten a strap around the tread so the bead touches the rim, like jcl22 said.
2018 Toro Workman HDX-D Diesel Utility Cart (A66734)
2018 Toro Workman...
2015 PETERBILT 389 T/A 6X4 SLEEPER TRUCK TRACTOR (A69167)
2015 PETERBILT 389...
PALLET OF TOOLBOXES (A68842)
PALLET OF...
2015 Ford F-250 Knapheide Service Truck (A66736)
2015 Ford F-250...
2016 FREIGHTLINER CORONADO 122 SD (A67714)
2016 FREIGHTLINER...
Unused 2023 Unused HLA 2.5 Yard Loader Bucket Attachment (A66734)
Unused 2023 Unused...
