First welder advice
/ First welder advice #21
Sort of like soldering but more like welding with an oxy-ace torch than anything. But of course you are melting the parent metal as well as the filler
Your right, I guess TIG would be more like Gas welding with a electricity instead of a flame.
That is very true with dual shield. And a lot of the gas-less fluxcore as well. Here is some NR-212 I ran, all the slag and splatter came right off with a wire wheel on a 4-inch grinder.
Those are some pretty welds. They look like they dug in quite well too. Mine sometimes look that way, but never as straight.
/ First welder advice #22
Lets make it simple, buy a AC/DC stick machine. You can weld just about anything, inside and outside including aluminum and stainless. Yes I agree with thin stuff it is simpler to use a mig but you can get good with the thin stuff with DC- also. No worry about cold lap just undercut and usually a non issue anyway. Up and running for $500 ish. CJ
Thanks guys. I think I may go for the DC stick. The ones you have mentioned are:
Everlast PA160 - entry level but solid
Everlast PA-300 - adjustable hot start
Longevity Stickweld 250 - adjustable hot start
Any others I should consider?
/ First welder advice #24
/ First welder advice #26
Yes you did!:D Hey I'm bad enough at spending my money, but I could really spend yours.:laughing:
/ First welder advice #27
Everlast PA-200 too.
/ First welder advice #29
He he, I would suggest a SA-200 but I have heard someone was hoarding them!! CJ
I heard they were all up in the Pacific Northwest somewhere.;)
/ First welder advice #30
I just got one of those. I got the model that can run either 120 or 240 volts. I'm very inpressd. I had a PA140(sold it) that was great too.
I like the PA200 for the increased output and better 6011/6010 capability.
/ First welder advice #31
Where? I could use a few more!:rolleyes::laughing:
Dan you may not believe it, and I sure wouldn't have without seeing it with my own eyes! But the PA-200 with stack 6010 every bit as nice as either one of my SA-200 Short Hoods. You just have to hold a closer arc length is all.
/ First welder advice #32
I know, that's why I bought it.
I'd say even better. And I don't have to keep any shorter arc than I normaly do. And I can whip and pause if I need to.
The PA140 wouldn't. I would have liked to send it to you to see what you could do with it, but I sold it to a TBN member.
Like night and day between the PA140 and the PA200.
/ First welder advice #33
Yeah when I first got my PA-200 I was floored at the quality of arc. For the price I don't think you'll find a better welder. I'd love to get my hands on a PA-300:licking:, if Mark wasn't such a cheap skate:rolleyes: he would send me one to play with!:laughing:
/ First welder advice #34
The new 200st, although it has a reduced duty cycle, it is supposed to be a little more tolerant of a longer arc.
Mark,
I will be in touch if Santa has not already done so.
A few more questions if I may... How light of material can I do stick welding? I will probably want to do some decorative/artistic work from time to time such as making bases for tables, podiums, etc. Would this change the recommendations from my first set of criteria or can I do that also with stick?
/ First welder advice #39
A lot of that will depend on your ability, and joint configuration. Personally I've never been good with thin material stick welding. At one point I would get nervous with 3/8-inch thick material!:eek: I just don't think I could weld 16-GA with stick, maybe a lap joint.:scratchchin: 10-GA I might be able to pull that off. But this is the reason I have a Mig, and Tig welder, to work around my short comings!;)
/ First welder advice #40
FWIW, I believe the PA160 has been replaced by the PA160 STH, which has pedal control for TIG. So it's a true dual process welder. Talk to Mark and he'll sort you out.
1070 (A64280)
1070 (A64280)
2007 Sterling L9500 Fuel & Lube Y22693 (A62613)
2007 Sterling...
Ford TW20 (A64119)
Ford TW20 (A64119)
EZ Trail 3400 (A63688)
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
UNUSED WOLVERINE HYD SCREENING BUCKET (A64281)
UNUSED WOLVERINE...
