Finally, a generator powered EV?
/ Finally, a generator powered EV? #1
Jstpssng
Epic Contributor
Maine
Kubota L3301
This is an interesting article which describes what has been mentioned here before; Nissan claims it's made a more thermally efficient gas engine, but there's a catch. Apparently Nissan has been offering it for about 5 years, just not on this side of the pond.
A couple of things which weren't mentioned; they've been doing this with locomotives for years, sans the battery. And what's more efficient than a gas engine? The same engine which is powering many of our tractors.
/ Finally, a generator powered EV? #2
A turbo diesel is about 33% efficient, about the same as a dino fuel powered boiler generating steam. Most of our tractors are not turbo, probably about 20% less, e.g. about 27%. You can get more efficiency by powering a gas turbine and then generating steam from its exhaust, more like 67%. We had a driver like this generating steam on a ketone dewaxing unit in Texas. The driver was used to compress propane for refrigeration instead of directly generating power like in a power plant.
/ Finally, a generator powered EV? #3
It only took start stop technology about 30 years to show up in the US.
/ Finally, a generator powered EV? #4
You really ought to get out more. A Chevy Volt is an all electric car with a generator backup. The gas motor does not engage the driveline it only provide electricity.
Good grief.
/ Finally, a generator powered EV? #6
Chevy Volts can and do engage the engine to drive wheels in some situations. Its done through planetary gear sets and clutches because of efficiency.
Gen 1 and Gen 2 do it differently though since the design advanced in Gen 2.
I always thought GM would Upsize the Volt design for full size trucks.
Towing a decent size trailer would be nice to have the generator helping when climbing a mountain or going the last few miles when the batteries are depleted.
2008 Sterling Acterra 2,000 Gallon Water Truck (A66736)
2008 Sterling...
2012 Ford F-250 Crew Cab Pickup Truck (A64556)
2012 Ford F-250...
2018 RAM 5500 FLATBED (A67714)
2018 RAM 5500...
2 WHEELBARROWS (A68842)
2 WHEELBARROWS...
2016 CHEVROLET CAPRICE CAR (A66091)
2016 CHEVROLET...
2010 John Deere 4720 58HP 4WD Utility Loader Tractor w/ Titan Aerator (A66734)
2010 John Deere...
