Fence Post Spacing
   / Fence Post Spacing #51
Hey Soundguy, I have seen a horse fire off a shot and get a hoof through cheap 2x4 but never the better stuff like RedBrand.
I think that Soundguy, MikePA, and others have seen my posts on equine fencing and know that I have pretty strong opinions of fencing based on the mistakes I have made and seen made, so no offense meant to anyone. Sharing knowledge is a good idea. To me, the best horse fence is like the one that wroughtnharv has in his post, steel pipe fence with good no climb but here is my recollection of my earlier post.
1. Steel pipe with no climb – Steel acts as a good fairly solid barrier so a horse wont charge through it. In most cases a horse can actually bounce off a steel fence with only bruises. The no climb (do a search on RedBrand No Climb) keeps feet from getting stuck. The steel pipe and no climb are also the best deterrents to rustling. And yes, it is far more common than most people know…….
2. No climb with hot wire and T posts – Same thing with the no climb as I said above. Just set good corners, stretch it tight and I would run a hot wire top and bottom. Also run a stand up steel post every 4-5 T posts to increase stiffness of the fence. Get some big PVC caps that slip over the exposed T post tops, fill it with construction adhesive and shove them over the top. In case the horse is a horse and hits the top of the T post you are less likely to have a vet bill.
3. 3-4 rail board with no climb – Same as the two above but, as mentioned, if a horse runs into a board fence it will shatter and can really tear up a horse with the pointed ends. If the wood is heavy it can be pretty good to keep the horses in including being a deterrent to rustlers.
4. 3-4 rail vinyl fence with no climb– Same as board fence but those rails can pop out pretty easily. If you want a nice looking fence but one that is also pretty horse safe then set up your vinyl fence, set ‘em in concrete, set steel pipe corners and then every 40’ set a vertical steel pipe. Set the corners and inline steel pipes 1” inside the vinyl and in concrete. Then set the no climb between the steel and vinyl, pull it tight from the corners, tie it off to the inline steel and between the inline steel pipes attach to they vinyl. Make sure you run hot wire around the inside.
5. 8-12 strand high tension steel wire – I actually like this set up. If the spacing is close on the wire and the tension is high, its very hard for a horse to get a hoof in between. I think it looks nice and neat and also keep the neighbors dogs that pack up from worrying the livestock.
6. Centaur vinyl coated multi wire fencing – sort of between multi strand high tension and vinyl. The Burbank equestrian center used this a number of years ago and all I can say is it does not hold its age well. It looked good new but they had to keep tightening it every year. It got to the point were they would have to pull it apart, reset the tighteners and then pull it again. It also does nothing to keep the dogs out and it’s easy for the horses to lean on it.
7. Rope/Tape electric fencing – Much like the Centaur fencing it does not stand up well over time. Gravity takes a toll on it. One of the little event centers in our area got talked into setting up the tape fence and I saw a couple of spooked horses literally run right through it. Fight or Flight is hard to overcome even if they know it’s hot.
8. Barb wire – For horses, it aint gonna happen if I can help it. Horses are just an accident looking for a place to happen. God made them grazers so fencing them with anything is creating problems. Having said that, any horse that is entrusted to my care deserves the best I can offer regardless if they are national caliber reined cow horse or a broke down rescued pasture ornament. I suspect the argument of barb wire is a little like the dispute I got into a couple of weeks ago with a local facility owner. They have about 30 horses on an exposed hill. No shade, small fenced pastures with only Star Thistle, watered once a day, flies in black clouds that worry them constantly, with weeks of 105+ degree days with the sun just beating down on them. The owners attitude was that horses all over have it worse than these horses so it’s not so bad. I don’t understand that attitude. Just because there are worse things does not mean that this is right.
So that’s my take….
Mark
   / Fence Post Spacing #52
</font><font color="blue" class="small">( I have seen a horse fire off a shot and get a hoof through cheap 2x4 but never the better stuff like RedBrand )</font>
Welded wire? I wouldn't keep anything but small dogs in welded wire.. you can't even stretch that stuff without breaking it.
I use the redbrand myself.. etc
Soundguy
   / Fence Post Spacing #53
</font><font color="blueclass=small">( Also ask a vet how many thousands of horses are in a barbed wire fence now and have no trouble, as stated before any horse that will run into a fence can get hurt no matter what type. )</font>
Thanks for your opinion, I did graduate from the University of Florida vet school over twenty five years ago and have had horses all my life,
Remember - HORSES AND BARBED WIRE DO NOT MIX
Tell them your vet said so.... /forums/images/graemlins/wink.gif
   / Fence Post Spacing #54
</font><font color="blue" class="small">( Never understood why anyone would want a horse. Just get a motorcylce, you don't have to feed it every day, don't have to pay the vet and when your done with it you just put it up and forget about it. /forums/images/graemlins/grin.gif /forums/images/graemlins/wink.gif It does make for an enjoyable topic when people are passionate about it. )</font>
Thanks for the suggestion, but I've already got six motorcycles. /forums/images/graemlins/grin.gif
   / Fence Post Spacing #55
Mudcat,
Won't be much longer and it will cost more to feed a motorcycle than it does to feed a horse with the price of gas going up the way it is.
Farwell
   / Fence Post Spacing #56
But you don't have to feed the motorcycle if you arn't riding it.
   / Fence Post Spacing #57
Until I got on this forum, I had never heard of not using barb wire for horses. Practically everyone around here used barbed wire, 3-5 strands or woven wire topped (and sometimes bottomed) with barbed wire. We've had horses and donkeys for 30 years, always staying in barbed wire, and never had a problem...I guess either we're safe forever or we're due. Of course, I've heard some people say to only get on a horse from one side or the other, but nobody told our horses, cause we get on and off from either side. There are a fair amount of predators, coyotes and bobcats and wild dogs around here as well. You could always look at it that if the horse has little enough sense to get caught in the fence, maybe the herd needs to be thinned anyway.
I'm more inclined to go with the motorcycle or four wheeler than the horses too...but somehow, I've got five horses and no motorcycle...anybody want to trade?
   / Fence Post Spacing #58
No problem, you learn something new everyday, even if it takes you thirty or more years to get to that day.
Oh, BTW, motorcycles, ATVs, and barbed wire don't mix well either......it may take thirty or more years to understand that too but once it happens you'll understand it well right away. /forums/images/graemlins/wink.gif
   / Fence Post Spacing #59
</font><font color="blue" class="small">( Practically everyone around here used barbed wire, 3-5 strands or woven wire topped (and sometimes bottomed) with barbed wire. )</font>
For what it's worth, the horse farm i got 2 of my horses from also had 5- strand barbed wire fences.... other than some checking on the horses faces.. no other problems.. though.. as most state.. If I was putting up new fence.. i wouldn't go up with barb wire if it was for horses.
Also.. as for a top 'barb' wire over a woven fence.. that's pretty much ok... that's just a deterent for horses leaning over the fence.. not the same kind of problems encountered with an all 'stranded' wire fence.
Soundguy
   / Fence Post Spacing #60
I guess I can kind of understand horses getting into fences - haven't seen it and don't plan to change any of my fencing practices, but I'll take your educated word for it...
...but so far I have managed to keep tractors and trucks (never had an ATV or Motorcycle) out of fencelines, and I doubt it's good to run a motor vehicle (except maybe a dozer) into ANY kind of fence, right? I find five strands of barbed wire to be the most effective and cost-effective way to keep cows and horses home, and it works pretty good against trespassers. However, I do have some problems with deer tying the bottom strands down and lifting the middle strands up and tying them off...because I know the deer hunters wouldn't do it.
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
2009 Peterbilt 384 Semi (A59814)
2009 Peterbilt 384...
NEW Woods 6ft Finish Mower (A56436)
NEW Woods 6ft...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
Enclosed Service Truck (A55788)
Enclosed Service...
