Factory headlights?
/ Factory headlights?
Well the led lights I ordered came in......
I just installed one of them and tested in the dark to see if they were in fact brighter. You can see that the reflector housing that the bulb resides in is lit more fully than the incandescent bulb. As far a brightness, both my wife and I could not say. We were both blind from looking at the lit bulbs in the dark. For some reason the LED has a whiter light than the other, not sure why but it seems brighter because it is soo white looking
LED bulb is more pronounced as well within the housing
See for yourself, hope this will work for now; 16 bucks and free shipping from amazon
/ Factory headlights? #22
So, if you have them both in, are they brighter than the OEM incandescent lamps? Is there a pronounced difference?
James
The light was a bit brighter with the new bulbs..... Where there was a truly notable difference was the indirect light (light around the sides of the tractor). Hmmm, you could see more of what is beside the tractor that with the original bulbs. The field of vision was greater after the install.
These new bulbs were "plug and play" with no tools required.
/ Factory headlights? #24
James
Cool! ... Thanks.
ALUMINUM CUTTING BOARD, (2) POLY CUTTING BOARDS (A64278)
ALUMINUM CUTTING...
1993 Transcraft DTL140W2 38Ft 60 Ton Spread Axle Step Deck T/A Trailer (A64194)
1993 Transcraft...
LOT OF TRANSPLANTER PARTS (A64278)
LOT OF...
Hydraulic Breaker Mini Skid Steer Attachment (A64553)
Hydraulic Breaker...
2016 Freightliner 108SD T/A Rolloff Truck (A64194)
2016 Freightliner...
TAYLOR S/A LOOSE LEAF TRAILER (A64278)
TAYLOR S/A LOOSE...
