Factory headlights?
/ Factory headlights?
Well the led lights I ordered came in......
I just installed one of them and tested in the dark to see if they were in fact brighter. You can see that the reflector housing that the bulb resides in is lit more fully than the incandescent bulb. As far a brightness, both my wife and I could not say. We were both blind from looking at the lit bulbs in the dark. For some reason the LED has a whiter light than the other, not sure why but it seems brighter because it is soo white looking
LED bulb is more pronounced as well within the housing
See for yourself, hope this will work for now; 16 bucks and free shipping from amazon
/ Factory headlights? #22
So, if you have them both in, are they brighter than the OEM incandescent lamps? Is there a pronounced difference?
James
The light was a bit brighter with the new bulbs..... Where there was a truly notable difference was the indirect light (light around the sides of the tractor). Hmmm, you could see more of what is beside the tractor that with the original bulbs. The field of vision was greater after the install.
These new bulbs were "plug and play" with no tools required.
/ Factory headlights? #24
James
Cool! ... Thanks.
Deutz 4-Cylinder Air-Cooled Industrial Diesel Engine (A63689)
Deutz 4-Cylinder...
2013 Ford Transit Connect Cargo Van (A61573)
2013 Ford Transit...
2011 Ford F-450 Crew Cab Mason Dump Truck (A61573)
2011 Ford F-450...
2013 Ford F-350 Knapheide Service Truck (A61573)
2013 Ford F-350...
(4) MOUNTED 2000 LB TRAILER JACKS (A64280)
(4) MOUNTED 2000...
John Deere 4955 (A64119)
John Deere 4955...
